Hi, I got completely stopped by quite simple issue:
Node sends data (i.e. temperature) but then I want this payload to go to the next one ONLY if the switch (input boolean) is ON. Apparently, when I add current state node, on the output of it I have "on" or "off" instead of what I wanted: the temperature from the previous node.
I am missing simple bit probably but I am not able to go further. Is there any guru who does not mind to help to the newbie?
Thx.
