The difference is supposed to be if -
L = 0 it sends on/off depending on the value h
if
L = 1 it sends on/off depending if r = 0 or 1.
if
Compare how you are returning the results
Here is how it would be done with no code, using switch nodes
I think the logic is correct but had to look at your function so may be wrong.
[{"id":"8c365de7bc347d93","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"123/test","payload":"70","payloadType":"str","x":180,"y":660,"wires":[["1f4de87ca2d02a18"]]},{"id":"1f4de87ca2d02a18","type":"csv","z":"d58a0e9fb6feb9d6","name":"","sep":",","hdrin":"","hdrout":"none","multi":"one","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":370,"y":620,"wires":[["74972ad4ebf0f745"]]},{"id":"d6ac64cdbfdaec55","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"123/test","payload":"60","payloadType":"str","x":170,"y":700,"wires":[["1f4de87ca2d02a18"]]},{"id":"74972ad4ebf0f745","type":"change","z":"d58a0e9fb6feb9d6","name":"","rules":[{"t":"move","p":"payload.col1","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"test","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":700,"wires":[["e51d38ab37b6ee27"]]},{"id":"e51d38ab37b6ee27","type":"join","z":"d58a0e9fb6feb9d6","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":350,"y":820,"wires":[["bec8151e84814f6a","3d5240314528daaf"]]},{"id":"688d1bf943e84c4b","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"raspberry","payload":"1","payloadType":"num","x":170,"y":780,"wires":[["e51d38ab37b6ee27"]]},{"id":"79cda72e5db0ecdd","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"raspberry","payload":"0","payloadType":"num","x":170,"y":820,"wires":[["e51d38ab37b6ee27"]]},{"id":"e2989af89ef6c16d","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"light","payload":"1","payloadType":"num","x":170,"y":960,"wires":[["e51d38ab37b6ee27"]]},{"id":"82a86590ec234930","type":"inject","z":"d58a0e9fb6feb9d6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"light","payload":"0","payloadType":"num","x":170,"y":1000,"wires":[["e51d38ab37b6ee27"]]},{"id":"bec8151e84814f6a","type":"debug","z":"d58a0e9fb6feb9d6","name":"debug 308","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":430,"y":900,"wires":[]},{"id":"3d5240314528daaf","type":"switch","z":"d58a0e9fb6feb9d6","name":"light 0 or 1","property":"payload.light","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":550,"y":820,"wires":[["ab5aa9c4d0b0b214"],["03c0a53faf3d264e"]]},{"id":"ab5aa9c4d0b0b214","type":"switch","z":"d58a0e9fb6feb9d6","name":"123/test <= 63","property":"payload.test","propertyType":"msg","rules":[{"t":"lte","v":"63","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":700,"y":780,"wires":[["d136bcc6f8f1403d","1e6ce190a1ebf511"],["57b068e8d10de517","325d2d64238dfae9"]]},{"id":"03c0a53faf3d264e","type":"switch","z":"d58a0e9fb6feb9d6","name":"1raspbery 0 or 1","property":"payload.raspberry","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":700,"y":840,"wires":[["d136bcc6f8f1403d","1e6ce190a1ebf511"],["57b068e8d10de517","325d2d64238dfae9"]]},{"id":"d136bcc6f8f1403d","type":"change","z":"d58a0e9fb6feb9d6","name":"payload on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":740,"wires":[["f27e8e3d8502edd8"]]},{"id":"57b068e8d10de517","type":"change","z":"d58a0e9fb6feb9d6","name":"payload off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":780,"wires":[["f27e8e3d8502edd8"]]},{"id":"1e6ce190a1ebf511","type":"change","z":"d58a0e9fb6feb9d6","name":"payload off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":880,"wires":[["76280934705d17de"]]},{"id":"325d2d64238dfae9","type":"change","z":"d58a0e9fb6feb9d6","name":"payload on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":840,"wires":[["76280934705d17de"]]},{"id":"f27e8e3d8502edd8","type":"debug","z":"d58a0e9fb6feb9d6","name":"300","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1130,"y":760,"wires":[]},{"id":"76280934705d17de","type":"debug","z":"d58a0e9fb6feb9d6","name":"400","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1130,"y":860,"wires":[]}]
Thank you. That works!
Thank you very much to everyone who helped me. Very much appreciated.
Here is the full working flow if anyone is looking at this thread for ideas.
I will try and get better at code and get it working with the function node. Didn't look like I was too far away.
Have a great day!
"id": "d32e63247484353d",
"type": "Sonoff device Enhanced",
"z": "477a1a1df2873848",
"mode": "0",
"broker": "618e5d5400c6168e",
"device": "hum",
"name": "D",
"onValue": "ON",
"offValue": "OFF",
"toggleValue": "toggle",
"cmdPrefix": "cmnd",
"statPrefix": "stat",
"telePrefix": "tele",
"x": 910,
"y": 780,
"id": "960c09733082d103",
"mode": "0",
"device": "dry",
"name": "H",
"onValue": "ON",
"offValue": "OFF",
"x": 910,
"y": 680,
"id": "0402be4a53f5a346",
"type": "change",
"rules": [
"t": "move",
"p": "payload.col11",
"pt": "msg",
"to": "payload",
"tot": "msg"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "test",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 300,
"y": 580,
"0bb675eee7cf2b76"
"id": "3f939e8c0d640e59",
"type": "join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": true,
"timeout": "",
"count": "3",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 330,
"y": 740,
"a69dbcf04839b569",
"a768af12e5ad67b2"
"id": "02b89014e14395ba",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "raspberry",
"payload": "1",
"payloadType": "num",
"x": 130,
"y": 740,
"3f939e8c0d640e59"
"id": "877007e8dd221b64",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"payload": "0",
"x": 130,
"y": 780,
"3f939e8c0d640e59"
"id": "ad5dde851ad28d53",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "light",
"payload": "1",
"x": 150,
"y": 900,
"3f939e8c0d640e59"
"id": "f3c5d3b3afa30ce8",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "light",
"payload": "0",
"x": 150,
"y": 940,
"3f939e8c0d640e59"
"id": "a69dbcf04839b569",
"type": "switch",
"name": "light 0 or 1",
"property": "payload.light",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 490,
"y": 740,
"4289e36e940eca58"
"f6989098c5f9fd0c"
"id": "4289e36e940eca58",
"type": "switch",
"name": "123/test <= 63",
"property": "payload.test",
"rules": [
"t": "lte",
"v": "63",
"vt": "str"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 500,
"y": 680,
"07e7b1d747126bf1",
"185392825f399686"
"e030c2f9381d6756",
"52173a633ee8b27c"
"id": "f6989098c5f9fd0c",
"type": "switch",
"name": "1raspbery 0 or 1",
"property": "payload.raspberry",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 500,
"y": 800,
"07e7b1d747126bf1",
"185392825f399686"
"e030c2f9381d6756",
"52173a633ee8b27c"
"id": "07e7b1d747126bf1",
"type": "change",
"name": "payload on",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "on",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 730,
"y": 660,
"960c09733082d103"
"id": "e030c2f9381d6756",
"type": "change",
"name": "payload off",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "off",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 730,
"y": 700,
"960c09733082d103"
"id": "185392825f399686",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "off",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 730,
"y": 800,
"d32e63247484353d"
"id": "52173a633ee8b27c",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "on",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 730,
"y": 760,
"d32e63247484353d"
"id": "cb1d46bbc7b63138",
"type": "mqtt in",
"qos": "2",
"datatype": "json",
"broker": "f03eb60e5379e1a3",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 700,
"3f939e8c0d640e59"
"id": "c590cc035274bb9a",
"type": "cronplus",
"outputField": "payload",
"timeZone": "",
"persistDynamic": false,
"commandResponseMsgOutput": "output1",
"outputs": 1,
"options": [
"name": "schedule1",
"topic": "light",
"payload": "1",
"expressionType": "cron",
"expression": "0 00 09 * * * *",
"location": "",
"offset": "0",
"solarType": "all",
"solarEvents": "sunrise,sunset"
"name": "schedule2",
"topic": "light",
"payload": "0",
"expression": "0 00 03 * * * *",
"location": "",
"offset": "0",
"solarType": "all",
"x": 140,
"y": 860,
"3f939e8c0d640e59"
"id": "0bb675eee7cf2b76",
"type": "calculator",
"inputMsgField": "payload",
"outputMsgField": "payload",
"operation": "mult",
"constant": "100",
"round": false,
"decimals": 0,
"x": 260,
"y": 640,
"3f939e8c0d640e59"
"id": "a768af12e5ad67b2",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 690,
"y": 880,
"id": "d11f4fe99323110c",
"type": "inject",
"name": "80",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "123/test",
"payload": "2023/06/08 13:37:33,1,405.133,7.848,2,26.6575,29.5926,3,3.046,27.0,0.80,101.67",
"payloadType": "str",
"x": 110,
"y": 540,
"6fc3edac259d0209"
"id": "6f5298f2f9d97d6a",
"type": "inject",
"name": "50",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"payload": "2023/06/08 13:37:33,1,405.133,7.848,2,26.6575,29.5926,3,3.046,27.0,0.50,101.67",
"x": 110,
"y": 480,
"6fc3edac259d0209"
"id": "6fc3edac259d0209",
"type": "csv",
"sep": ",",
"hdrin": "",
"hdrout": "none",
"multi": "one",
"ret": "\\n",
"temp": "",
"skip": "0",
"strings": true,
"include_empty_strings": "",
"include_null_values": "",
"x": 270,
"y": 360,
"0ee70e030db1ecfe",
"0402be4a53f5a346"
"id": "618e5d5400c6168e",
"type": "mqtt-broker",
"name": "Mosquitto",
"broker": "localhost",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
"id": "f03eb60e5379e1a3",
"name": "rasp1",
"broker": "192.168.0.59",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "60",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
you should indent things to make them readable. Here is your original code from one of your functions
let h = msg.payload.col1
let r = msg.payload.raspberry
let l = msg.payload.light
if (l==0){
if (h <= 63) msg.payload = "on";
if (h >63) msg.payload = "off";
if (l==1){
if (r == 0)
return [msg.payload = "on"]
if (r == 1)
return [msg.payload = "off"]
Here is it indented with the code for the if (l==1) fixed and the removal of the second return msg. Hopefully this will help you in teh future.
if (l == 0) {
if (h > 63) msg.payload = "off";
if (l == 1) {
if (r == 0)
msg.payload = "on"
if (r == 1)
msg.payload = "off"
