I use a function node to connect to socket.io, thus creating a socket object in the Start tab.
I need access to that socket object in the Stop section, to close the connection again.
Alternatively, node.on('close', ...) would work, but node#on does not seem to be available in the Setup tab.
So here is the question:
How do I access objects created in the start code from the stop code?
