Function node help
Hi
I must be missing something simple but i am trying to return from the below number to zero decimal places, nothing i try seems to work, any suggestion appreciated
const numbers = [bedroomtemp, bedroomventtemp, loungeventtemp, loungetemp];
let max = Math.max.apply(null, numbers);
let min = Math.min.apply(null, numbers);
What output are you expecting?
The main and max of 4 numbers as integer?
The values and name of which variable was min/max?
The result as an array? Object?
A combination of Array.map & Math.round or Math.ceil will probably be what you want.
I am expecting two variables, one "min" and one "max". I tried Math.round but could't get it to work, quite convinced it was a case of incorrect formatting when i typed it in
//dummy data - update as required
const bedroomtemp = 21.2, bedroomventtemp=20.9, loungeventtemp=23.123, loungetemp=18.321
msg.payload = {
  max: Math.round(Math.max.apply(null, numbers)),
  min: Math.round(Math.min.apply(null, numbers))
return msg
thanks, copied your code and changed to make it how i need it but can't get it through to the next node. If i send msg.control = {min:10, max:80} it works fine and the debug gives me the below image
whne i try the round statemement it give me this
msg.control = {
minmax: {min:(Math.round(Math.min.apply(null, numbers))), max:(Math.round(Math.max.apply(null, numbers)))}
return msg
//msg.control = {min:10, max:80}
if thats what you need, then dont add the minmax property!
msg.control = {
  min: (Math.round(Math.min.apply(null, numbers))),
return msg
or if it makes more sense to you...
msg.control = { };
msg.control.min = Math.round(Math.min.apply(null, numbers));
msg.control.max = Math.round(Math.max.apply(null, numbers));
return msg
Thanks, works perfectly and the second option made it clear in my head, don't do much of this and sometimes can't see the wood for the trees
