Function node sends multiple messages instead of one
Here is the json for the issue:-
[{"id":"4b211f23c08b43f4","type":"tab","label":"Flow 5","disabled":false,"info":"","env":},{"id":"af5483388c10dfb5","type":"function","z":"4b211f23c08b43f4","name":"Combine 6 global variables into one payload","func":"msg.payload = \n\n{\n\n "solarPvId" : flow.get("solarPvId"),\n "solarPvTimestamp" : flow.get("solarPvTimestamp"),\n "currentGeneratingUnitsW" : flow.get("currentGeneratingUnitsW"),\n "exportingUnintsW" : flow.get("exportingUnintsW"),\n "currentDayGeneratedW" : flow.get("currentDayGeneratedW"),\n "currentDayExportedW" : flow.get("currentDayExportedW")\n\n}\nnode.send(msg);\n\n//return msg;\n\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":,"x":850,"y":140,"wires":[["8284852709ca22a8"]]},{"id":"8284852709ca22a8","type":"debug","z":"4b211f23c08b43f4","name":"dB payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1190,"y":140,"wires":},{"id":"638a99cd0d575a4e","type":"msg-speed","z":"4b211f23c08b43f4","name":"","frequency":"hour","interval":1,"estimation":false,"ignore":false,"pauseAtStartup":false,"topicDependent":false,"x":510,"y":140,"wires":[["af5483388c10dfb5"],]},{"id":"ea1bc11cc99b2091","type":"inject","z":"4b211f23c08b43f4","name":"Every 1m","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":250,"y":140,"wires":[["638a99cd0d575a4e"]]}]
obviously the function isn't getting any data now as the flow variables aren't being created, but the output is still showing messages at 1/second (timestamp on when something comes from a node within the flow):-
