Hi all, I'm writing a function in func-exec node
msg.topic = ""
var array = [];
var exec = child_process.exec('pgrep firefox', (error, stdout, stderr) => {
if (error) {
console.info("false")
msg.payload = false
msg.topic = "error connection ui"
if (stdout != ""){
var splitString = stdout.split(" ")
for (var i = 0; i < splitString.length; i++){
array.push(parseInt(splitString[i]))
console.info(array)
msg.payload = array
console.info(msg.payload)
unfortunately the msg.payload is always undefined while array is corrected not empty as I can see on the console.
can some help me to understand where I wrong?
many thanks
E1cid
18 July 2022 13:42
2
does the second if () require a return?
Hi @denissanga
You cannot use return to send a message from inside a callback function - you can only use return at the top level of the code.
To send a message from inside a callback, you need to use node.send(msg) - Writing Functions : Node-RED
many thanks
I try with this
msg.topic = ""
var array = [];
var exec = child_process.exec('pgrep firefox', msg, (error, stdout, stderr) => {
if (error) {
msg.payload = false
node.send(msg)
if (stdout != ""){
console.info("out1 " + array)
msg.payload = array
node.send(msg)
console.info("out2 " + msg.payload)
but I obtain
out1 123345
out2 true
What do you expect to get?
If you only want it to send a message once the exec has finished, then delete the return msg line at the end.
I would obtain 123345...there is no way with this approach?
I do not understand what you mean.
You have said you are getting:
out1 12324123
That tells us the console.info you have inside the callback is being called... so we can assume the next two lines are also being called which will cause a message to be sent:
msg.payload = array
node.send(msg)
Have you connected a Debug node to the output of the Function to see what message it is sending?
