Sub-Flow to use only 1 database node keeping all database information in only one place.
[{"id":"4639c7fae2510b5a","type":"subflow","name":"PrepBD","info":"","category":"","in":[{"x":80,"y":100,"wires":[{"id":"8cc0b55b7d0743c0"}]}],"out":[{"x":1020,"y":100,"wires":[{"id":"4135b832b386a610","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"8cc0b55b7d0743c0","type":"change","z":"4639c7fae2510b5a","name":"copy flow/global to msg","rules":[{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"payload.ip","pt":"msg","to":"#:(persistent)::IP_vGlobalBD","tot":"global"},{"t":"set","p":"payload.porta","pt":"msg","to":"#:(persistent)::Porta_vGlobalBD","tot":"global"},{"t":"set","p":"payload.usuario","pt":"msg","to":"#:(persistent)::Usuario_vGlobalBD","tot":"global"},{"t":"set","p":"payload.senha","pt":"msg","to":"#:(persistent)::Senha_vGlobalBD","tot":"global"},{"t":"set","p":"payload.nomeBD","pt":"msg","to":"#:(persistent)::NomeBD_vGlobalBD","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":100,"wires":[["effa65099dd2a525"]]},{"id":"4135b832b386a610","type":"mysql2","z":"4639c7fae2510b5a","name":"","server":"","bind":"","topic":"","x":760,"y":100,"wires":[[]]},{"id":"effa65099dd2a525","type":"function","z":"4639c7fae2510b5a","name":"prep_MQTT_Conn","func":"\nconst ip = msg.payload.ip\nconst porta = msg.payload.porta\nconst usuario = msg.payload.usuario\nconst senha = msg.payload.senha\nconst nomeBD = msg.payload.nomeBD\n\nmsg.server = {\n \"host\": ip,\n \"port\": porta,\n \"username\": usuario,\n \"password\": senha,\n \"db\": nomeBD\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":100,"wires":[["4135b832b386a610"]]},{"id":"eb96b8b79efaea17","type":"change","z":"4639c7fae2510b5a","name":"","rules":[{"t":"set","p":"server","pt":"msg","to":"{'host': $globalContext('IP_vGlobalBD'),\t 'port': $globalContext('Porta_vGlobalBD'),\t 'username': $globalContext('Usuario_vGlobalBD'),\t 'password': $globalContext('Senha_vGlobalBD'),\t 'bd': \"TelemetriaEnervision\"\t }","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[[]]},{"id":"4a50ea77c5d0ed5b","type":"comment","z":"4639c7fae2510b5a","name":"Quem sabe futuro usar esse Change","info":"Não consegui fazer funcionar com o mysql2, ele diz que o nome do banco de dados não está selecionado.","x":320,"y":220,"wires":[]}]
Sample use:
