How to use the function to compare 2 inputs and a switch input
[{"id":"c04670e4.3dd52","type":"ui_numeric","z":"bcc6b76b.ea3138","name":"","label":"b","tooltip":"","group":"56625c74.7d32d4","order":2,"width":0,"height":0,"passthru":false,"topic":"","format":"{{value}}","min":0,"max":"30","step":"0.5","x":210,"y":800,"wires":[["7afc36a1.0c8618","19543d2e.8f95a3"]]},{"id":"1e363307.46b04d","type":"function","z":"bcc6b76b.ea3138","name":"","func":"context.node == context.node || 0;\ncontext.node1 == context.node1 || 0;\n\nif (msg.topic == 'a'){\n context.node = msg.payload;\n} else if (msg.topic == 'b'){\n context.node1 = msg.payload;\n}\n\nif (context.node >= context.node1){\n return{ topic: 'd', payload: 'koelen'}\n}else if (context.node <= context.node1){\n return{ topic: 'e', payload: 'uit'}\n}\n","outputs":1,"noerr":0,"x":770,"y":760,"wires":[["1cbb5e38.9596a2","ec99d7da.f66448"]]},{"id":"1cbb5e38.9596a2","type":"debug","z":"bcc6b76b.ea3138","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":920,"y":720,"wires":[]},{"id":"ec99d7da.f66448","type":"ui_text","z":"bcc6b76b.ea3138","group":"56625c74.7d32d4","order":5,"width":0,"height":0,"name":"","label":"kk","format":"{{msg.payload}}","layout":"row-spread","x":940,"y":780,"wires":[]},{"id":"f2dae333.5123c","type":"change","z":"bcc6b76b.ea3138","name":"a","rules":[{"t":"change","p":"topic","pt":"msg","from":"","fromt":"str","to":"","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":720,"wires":[["1e363307.46b04d","6eae978d.38f7e8"]]},{"id":"6eae978d.38f7e8","type":"debug","z":"bcc6b76b.ea3138","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":680,"wires":[]},{"id":"7afc36a1.0c8618","type":"debug","z":"bcc6b76b.ea3138","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":840,"wires":[]},{"id":"19543d2e.8f95a3","type":"change","z":"bcc6b76b.ea3138","name":"b","rules":[{"t":"change","p":"topic","pt":"msg","from":"","fromt":"num","to":"","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":780,"wires":[["1e363307.46b04d"]]},{"id":"84da0e5a.31b04","type":"ds18b20","z":"bcc6b76b.ea3138","name":"Koelkast","sensorid":"28-0516944078ff","timer":"1","x":480,"y":600,"wires":[["b28d4840.ef9ea8","620986bd.1efe78","f2dae333.5123c"]]},{"id":"56625c74.7d32d4","type":"ui_group","name":"Group 3","tab":"42678669.1270b8","order":1,"disp":true,"width":6},{"id":"42678669.1270b8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
