Function tried to send a message of type number
i am trying to do some basic calculations but keep getting the error 'function tried to send a message of type number'.
I read most forum discussion and added = {}; in the beginning of the flow for all variables.. but this did not fix the issue.
var meting = {};
var gem = {};
var stddev = {};
var gemstd = {};
var metstd = {};
meting = msg.payload;
gem = msg.average;
stddev = flow.get("stddev");
gemstd = gem + stddev;
metstd = meting + stddev;
meting.payload= msg.payload;
meting.topic= "meting";
gem.payload= msg.average;
gem.topic= "gemiddelde";
gemstd.topic = "gem +stddev";
gemstd.payload = gemstd;
metstd.topic = "meting +stddev";
metstd.payload = metstd;
return [meting, gem, metstd, gemstd]
the issue is probably obvision, but I can't find it....
You are correctly creating empty messages at the start, but then you say, for example,
which destroys the empty message you had already created. Then you say
which I am suprised does not generate an error. Possibly you intended to create a separate set of temporary variables instead of overwriting meting and the others.
after some reading I figured I should take out the 'var meting = {};' and 'var gem = {};'
since it deletes the payload before i use them... But also making that change did not resolve the issue:
var stddev = {};
var gemstd = {};
var metstd = {};
var meting = msg.payload;
var gem = msg.average;
meting.payload= meting;
gem.payload= gem;
return [gemstd, metstd, meting, gem]
I think those are correct, it is the overwriting of them that is the problem
Thanks Colin, i Understand. fixed it!
var G = {};
var GS = {};
var M = {};
var MS = {};
var stddev = flow.get("stddev");
var gemstd = gem + stddev;
var metstd = meting + stddev;
M.payload= meting;
M.topic= "meting";
G.payload= gem;
G.topic= "gemiddelde";
GS.topic = "gem +stddev";
GS.payload = gemstd;
MS.topic = "meting +stddev";
MS.payload = metstd;
return [G, GS, M, MS]
