functionGlobalContext for modules with "@" or "/" in name?
I've already implemented a functionGlobalContext in the settings.js file for binary_parser using the following, drawn from a specific online example using that module.
functionGlobalContext: {
        binary_parser:require('binary-parser').Parser,
and then in my function node....
var Packet = global.get('binary_parser');
var myheader = new Packet()
  .endianess("big")
  .uint8("version");
Now I'm trying to do the same for the following two modules, and I can't get them to work. I'm not sure if it's the "@" and/or "/" symbols, or a lack of an equivalent constructor? The equivalent of the .Parser at the end of the settings.js line? I've tried a lot of combinations with no luck.
Could anyone provide to me both the settings.js entry AND the code to add to the function (if any) to get this to work? I also tried implementing this in the "Setup" tab of the function node with no luck.
RTCM Module
NTRIP Module
Thank you for any help!
