functionGlobalContext
Hi.
Have problem with a function.If i disable the function with // Node-red starts but if i remove // and enable the function i get Error loading settings file: /home/pi/.node-red/settings.js
Any idéa??
requst disable
Have you installed the request module?
Does it just needs to be installed in the node-red folder or globally, or does it have to be mentioned inside package.json ?
Fairly certain it can be installed either -g globally or in the node-red folder. Just so long as it is resolved by require like any regular node application.
Installing it locally will automatically put it in package.json. So you should just need to go to your .node-red folder and
npm install request
The double slashes are used for commenting the same.
This part after slashes won't be executed!
