I have written this function that if the value x for a certain time
(Time1) is higher than the value y. All values are numbers. After I'm not familiar with javascript I do not know why the if loop with the counter does not work
x = msg.payload.down
y = msg.topic.topic1
time = msg.payload.Time1
z = 0
while (x >= y) {
if (z >= time){
msg.payload.Was = "Jetzt"
else {
z += 1
while (x < y) {
z = 0
So you are comparing x against y but don't change either x or y so the condition you are testing will never change.
while (x < y) {
z = 0
same thing and you need to close your while statement. (the function node should have flagged this with a red cross indicating a problem...)
See JavaScript while Loop
I find if you talk yourself through your code you will spot problems...
x = msg.payload.down //didnt declare x. Should be var x or let x
y = msg.topic.topic1 //didnt declare y. Should be var y or let y
time = msg.payload.Time1 //again no declare
z = 0 //you get the idea
while (x >= y) { //so loop round and round and round until x is > or = to y
if (z >= time){
else {
z += 1
} //end of loop - but hang on, x never changed - this will loop for ever!
while (x < y) {//again, loop round until x < y. where do you change x ?
z = 0
// <<-- missing a close brace here!
I suspect you think a new payload will update x and y.
You are not thinking in terms of node-red flow programming me thinks.
Perhaps you should describe what you are trying to achieve?
Perhaps we can guide you?
Thanks, yes I could use help and I hope it is understandable what I explain below.
I have a photodiode which gives me a number value of the voltage of the diode. And also I have a dashboard on which one set the desired voltage at which commanded (shutters down) to be executed. But the command he should be executed when the value of the photodiode for a certain time (Time1) falls below the value of a Dashboardslider
I will send you the exportet file later, if you need it.
it will be helpful to post screen shots of what you have done so far & the flow.
Remember to paste your exported flow between three backticks e.g.
your flow here
However, some pointers first...
- Checkout the trigger & delay node (read the info on the side-bar for clues)
- Get rid of the loop in the function
- Not least because you will cause an infinite loop and cause other issues
The problem is just that I can not connect to the Node red editor, which means I can not make screenshots or similar.
Probably because you flow/function is in an infinite loop!
So stop node-red and restart Node-RED with the --safe setting which starts node-red, loads your flow but doesn't deploy.
