Funnel Chart in Dashboard 2
Hi all,
I'm struggling to implement the horizontal Funnel Chart below in dashboard 2.0 template node,
and could use some help. I'm considering these two libraries (Option 1 is preferable):
  1. Vue Funnel Graph - Funnel graph drawing library for Vue.js.
  2. D3 Clone of FunnelGraph.js - a D3.js implementation of a funnel chart.
Here's my broken flow, based on the Echarts demo solution:
[{"id":"5b58efcc9731e50a","type":"ui-template","z":"9bcf538d070db3bc","group":"5a24a7294e508359","page":"","ui":"","name":"Funnel Chart","order":2,"width":0,"height":0,"head":"","format":"<template>\n\n  <div id=\"funnel-graph\"></div>\n</template>\n\n\n<script src=\"https://unpkg.com/vue-funnel-graph-js/dist/vue-funnel-graph.min.js\"></script>\n\n<script>\n\n  function init() {\n\n   \n          :width=\"width\"\n          :height=\"height\"\n          :labels=\"labels\"\n          :values=\"values\"\n          :colors=\"colors\"\n          :sub-labels=\"subLabels\"\n          :direction=\"direction\"\n          :gradient-direction=\"gradientDirection\"\n          :animated=\"true\"\n          :display-percentage=\"true\"},\n  \n      data: {\n        width: 400,\n        height: 400,\n        labels: ['Step 1', 'Step 2', 'Step 3', 'Step 4'],\n        subLabels: ['Sub 1', 'Sub 2', 'Sub 3'],\n        values: [[600, 400, 200, 100], [300, 200, 100, 50]],\n        colors: ['#FF5733', '#33FF57', '#3357FF'],\n        gradientDirection: 'horizontal',\n        direction: 'vertical'\n      }\n    });\n  }\n\n  // Run this code when the widget is built\n  let interval = setInterval(() => {\n    if (window.FunnelGraph) {\n      // Call init() to use VueFunnelGraph\n      init();\n      clearInterval(interval);\n    }\n  }, 100);\n</script>\n\n<style>\n  /* Define any styles here - supports raw CSS */\n  #funnel-graph {\n    width: 100%;\n    height: 400px;\n  }\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":490,"y":400,"wires":[[]]},{"id":"5a24a7294e508359","type":"ui-group","name":"Support","page":"22c235c0282c88f2","width":"12","height":"1","order":1,"showTitle":false,"className":"","visible":"true","disabled":"false"},{"id":"22c235c0282c88f2","type":"ui-page","name":"Help","ui":"0095684061591fec","path":"/help","icon":"mdi-chat-question","layout":"grid","theme":"44dd49330c02d4ba","order":10,"className":"","visible":"true","disabled":"false"},{"id":"0095684061591fec","type":"ui-base","name":"Enqode","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-control","ui-notification"],"showPathInSidebar":false,"navigationStyle":"icon"},{"id":"44dd49330c02d4ba","type":"ui-theme","name":"LightCyber","colors":{"surface":"#071438","primary":"#7300b5","bgPage":"#ebeef3","groupBg":"#ffffff","groupOutline":"#e6e6e6"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
Thanks in advance for your help!
Hi
Your template code has some errors...
Even so, there is an error when loading the external script, there is an issue on GitHub for that library
Error using with CDN · Issue #27 · greghub/vue-funnel-graph-js (github.com)
Considering that the last commit is more than 5 years ago, it could not be compatible with Vue3 and most likely some dependency is missing.
If you want to try, this is what I am using, similar to what I have to load ChartJs but removed the extra pieces...
You can see the error on the browser console window.
[{"id":"5b58efcc9731e50a","type":"ui-template","z":"76fa92b1d3123479","group":"5a24a7294e508359","page":"","ui":"","name":"Funnel Chart","order":2,"width":0,"height":0,"head":"","format":"<template>\n  <div id=\"funnel-graph\"></div>\n</template>\n\n\n<script src=\"https://unpkg.com/vue-funnel-graph-js/dist/vue-funnel-graph.min.js\"></script>\n\n<script>\n    export default {\n\n  data() {\n    this.mychart = null;\n    return {\n      \n    }\n  },\n  watch: {\n    msg: function () {\n    },\n  },\n  computed: {\n  },\n  methods: {\n    init: function () {\n      this.mychart = new window.VueFunnelGraph({\n          container: '.funnel-graph',\n          gradientDirection: 'horizontal',\n          data: {\n              labels: ['Impressions', 'Add To Cart', 'Buy'],\n              colors: ['orange', 'red'],\n              values: [12000, 5700, 360]\n          },\n          displayPercent: true,\n          direction: 'horizontal'\n      });\n  \n      this.mychart.draw();\n      console.log(this.mychart);\n\n      return (true);\n    },\n  },\n  mounted() {\n    // code here when the component is first loaded\n    let interval = setInterval(() => {\n      console.log('Attempting to Start');\n      if (window.VueFunnelGraph !== undefined) {\n        console.log('Going to start Chart');\n        if (this.init() == true) {\n          console.log('Chart downloaded and started');\n          clearInterval(interval);\n        } else {\n          console.log('Error Init Chart');\n        }\n      }\n    }, 250);\n  },\n  unmounted() {\n    // code here when the component is removed from the Dashboard\n    // i.e. when the user navigates away from the page\n  }\n}\n</script>\n\n<style>\n  /* Define any styles here - supports raw CSS */\n  #funnel-graph {\n    width: 100%;\n    height: 400px;\n  }\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1170,"y":440,"wires":[[]]},{"id":"5a24a7294e508359","type":"ui-group","name":"Support","page":"22c235c0282c88f2","width":"12","height":"1","order":1,"showTitle":false,"className":"","visible":"true","disabled":"false"},{"id":"22c235c0282c88f2","type":"ui-page","name":"Help","ui":"f10950b00cebceb1","path":"/help","icon":"mdi-chat-question","layout":"grid","theme":"44dd49330c02d4ba","order":10,"className":"","visible":"true","disabled":"false"},{"id":"f10950b00cebceb1","type":"ui-base","name":"UI Name","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"navigationStyle":"default","titleBarStyle":"default"},{"id":"44dd49330c02d4ba","type":"ui-theme","name":"LightCyber","colors":{"surface":"#071438","primary":"#7300b5","bgPage":"#ebeef3","groupBg":"#ffffff","groupOutline":"#e6e6e6"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
Thanks arturv2000! I appreciate your detailed response and insights;)
Despite trying various approaches, including D3 and checking for missing dependencies,
I hit a dead end with this library.
As a workaround, I created an HTML endpoint and served it as an iframe...
