Gateway Modbus/TCP para Ethernet/IP
Hi, I'm new here.
I need to convert the modbus / tcp protocol to ethernet / ip. Can someone help me?
Att,
Everaldo
Hi @Everaldo
where does Node-RED fit here? Or is this a general modbus question? Not sure we can help with the latter.
Olá! Estou em um projeto e preciso converter modbus/tcp em ethernet/ip. Já está operando porem ainda não consegui separar os registros array.
Hello! I'm on a project and need to convert modbus/tcp into ethernet/ip. It's already operating, but I haven't been able to separate the array records yet.
Can easily be done...
Step 1 - ingest data into node red using modbus node-red node.
Step 2 - Confirm data is being scanned into node-red then transform data into a format that can be handled using an ether-IP node. This is process is application dependent and may involve a number of nodes like function, change or switch nodes.
Step 3 - Connect transformed data stream to ether-IP node
Although we have never used node-red for ether-IP we have used the modbus connection for a project with around 5,000 data points and it has worked fine for about 2 years for data writing to a historian database. Uptime has been 100%.
Overall very solid, very stable and well suited to the type of application you are describing.
