Generate modbus flex sequence
I have a few registers to read using modbus flex:
To avoid modbus congestion,can anyone help me generate a sequence of registers/quantity to have as little queries as possible ?
For example :
numbers = [10,11,12,18,500,501,505]
should generate only 2 queries :
address 10 quantity 9
address 500 quantity 6
Are you asking for a general algorithm that will work with a random set of registers? If so that is more of a maths question than node red I think.
Yes. Exactly.
If the difference between the registers is higher than say 20, generate different a request. Otherwise combine them all in one read.
I tried a few things, didn't succeed just yet, hence the post here.
For now I make the all requests manually, and filter the output with the registers I need.
nevermind.figured it out :slight_smile:
Is it general enough to share ? Others may find it useful.
