Hi there,
As a beginner, I am stuck a little bit. Hope anybody can help
I have the following arr variable used as a settings file:
const arr = [
{ "zona": "Zone1", "ip": [10, 11, 12], },
{ "zona": "Zone2", "ip": [13, 14] },
{ "zona": "Zone3", "ip": [15] },
Can anybody help me generate msg.options for the dropdown widget from this?
I managed to show it using arr.map(function (x) { return x.zona; }); , but there are no values assigned to each name using this method.
I need to extract the following format from it [ { "Zone1" : "0" }, { "Zone2" : "1" }, { "Zone3", "2" } ]
Also is there a way do a search function based on the first number in this array , to return the index number if found, Search for 10,13 or 15 returns 0,1 or 2.
