Can you post a sample of the data you are returning from the mySQL node? I think you'll need to feed the data returned from the query through a function node to create a JSON object in the correct format to produce a table.
Based on the PDFMake example flows, and the below example JSON, this flow produces a table with a few rows and columns - it ends up stored in the root of your user directory. In my case C/Users/droberts/test.pdf
[{"id":"40aa0652.d1bf88","type":"pdfmake","z":"ced96e30.86933","name":"","outputType":"Buffer","inputProperty":"payload","options":"{}","outputProperty":"payload","x":580,"y":400,"wires":[["97d255cf.8bc138"]]},{"id":"30e9a280.04a94e","type":"inject","z":"ced96e30.86933","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"content\":[{\"layout\":\"lightHorizontalLines\",\"table\":{\"headerRows\":1,\"widths\":[\"*\",\"auto\",100,\"*\"],\"body\":[[\"First\",\"Second\",\"Third\",\"The last one\"],[\"First\",\"Second\",\"Third\",\"The last one\"],[\"First\",\"Second\",\"Third\",\"The last one\"],[\"Value 1\",\"Value 2\",\"Value 3\",\"Value 4\"]]}}]}","payloadType":"json","x":420,"y":400,"wires":[["40aa0652.d1bf88"]]},{"id":"97d255cf.8bc138","type":"file","z":"ced96e30.86933","name":"","filename":"test.pdf","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":740,"y":400,"wires":[[]]},{"id":"da72935b.7c159","type":"comment","z":"ced96e30.86933","name":"Simple Example PDF Table","info":"This is the simplest PDF test as seen in the pdfmake examples [here](http://pdfmake.org/playground.html)","x":470,"y":360,"wires":[]}]
var docDefinition = {
content: [
layout: 'lightHorizontalLines', // optional
table: {
// headers are automatically repeated if the table spans over multiple pages
// you can declare how many rows should be treated as headers
headerRows: 1,
widths: [ '*', 'auto', 100, '*' ],
body: [
[ 'First', 'Second', 'Third', 'The last one' ],
[ 'Value 1', 'Value 2', 'Value 3', 'Value 4' ],
[ { text: 'Bold value', bold: true }, 'Val 2', 'Val 3', 'Val 4' ]
https://pdfmake.github.io/docs/0.1/document-definition-object/tables/
