MySQL Database Output (>500 rows) to be added to pdfmake
I am reading data from mysql database. and want to publish this data to a pdf report along with other design elements. I could make a complete flow, thanks to all the help from various forum topics, however, I am struggling to put large data (>500 rows) into the pdf sheet. Problem is : I don't know how to define the iterations of data rows so that it can take all the rows data automatically. My example flow is as below:
        "id": "8ba699c1.0f9858",
        "type": "function",
        "z": "bf49b341.ae1dc",
        "name": "Table format",
        "func": "//datetime\nvar time = new Date().toLocaleString(\"de\");\n\n\nmsg.payload = {\n    pageOrientation: 'portrait',\n\tcontent: [\n\t   \t\t\t{\n\t\t\t    columnGap: 20,\n            columns: [\n               {\n\t\t\timage: msg.pellogo,\n\t\t    fit: [75, 75],\n\t\t\talignment: 'left'\n\t\t},\n\t\t\t\n\t\t\t{text: 'Daily Report _ Production', \n\t\t\t\tstyle: 'header',\n\t\talignment: 'center',\n\t\twidth: 300,\n\t\tmargin: [0,0,20,0]\n\t\t},\n\t\t\n\t\t{\n\t\t\timage: msg.stlogo,\n\t\t\tfit: [50,50],\n\t\t\talignment: 'right'\n\t\t},\n\t\t\n\t\t\t]\n\t\t\t},\n'\\n\\n',\n'Key Parameters for all Lines:',\n'\\n\\n',\n\t\t{\n\t\t\tstyle: 'DataTable',\n\t\t\talignment: 'center',\n\t\t\ttable: {\n\t\t\t    headerRows: 1,\n\t\t\t     fontSize: 7,\n\t\t\t\tbody: [\n\t\t\t\t\t[{text:'Line No', style: 'tableHeader'}, {text:'Plan Qty', style: 'tableHeader'}, {text:'Input Qty', style: 'tableHeader'}, {text:'Finshed Goods', style: 'tableHeader'} , {text:'Fall Off Rate', style: 'tableHeader'} , {text:'Productivity', style: 'tableHeader'}, {text:'Throughput Time', style: 'tableHeader'}, {text:'Total Tests', style: 'tableHeader'}, {text:'Pass Count', style: 'tableHeader'}, {text:'Fail Count', style: 'tableHeader'}, {text:'First Pass', style: 'tableHeader'}, {text:'R/W Pass', style: 'tableHeader'}, {text:'R/W Pending', style: 'tableHeader'}],\n[msg.payload],\n//[\"Line 1\", \"\"+a+\"\", \"\"+b+\"\", \"\"+c+\"\",\"\"+d+\"\", \"\"+e+\"\", \"\"+f+\"\", \"\"+g+\"\", \"\"+h+\"\", \"\"+i+\"\", \"\"+j+\"\", \"\"+k+\"\", \"\"+l+\"\"],\n//[\"Line 2\", \"\"+aa+\"\", \"\"+bb+\"\", \"\"+cc+\"\",\"\"+dd+\"\", \"\"+ee+\"\", \"\"+ff+\"\", \"\"+gg+\"\", \"\"+hh+\"\", \"\"+ii+\"\", \"\"+jj+\"\", \"\"+kk+\"\", \"\"+ll+\"\"],\n\n\t\t\t\t]\n\t\t\t}\n\t\t},\n'\\n\\n',\n'\\n\\n',\n'Line 5 - Daily Production Trend - Last 7 Days',\n\t\t\t{\n\t\t\timage: msg.image2,\n\t\t\tfit: [400,225],\n\t\t\talignment: 'center'\n\t\t},\n'\\n\\n',\n'Line 5 - FOR Analysis',\n\t\t\t{\n\t\t\timage: msg.image3,\n\t\t\tfit: [200,200],\n\t\t\talignment: 'center'\n\t\t},\n\t\t\t\n    ],\n    \tstyles: {\n\t\theader: {\n\t\t\tfontSize: 18,\n\t\t\tbold: true,\n\t\t\tmargin: [0, 0, 0, 10]\n\t\t\t\n\t\t},\n\t\tsubheader: {\n\t\t\tfontSize: 16,\n\t\t\tbold: true,\n\t\t\tmargin: [0, 10, 0, 5]\n\t\t},\n\t\ttableExample: {\n\t\t\tmargin: [0, 5, 0, 15],\n\t\t\talignment: 'right'\n\t\t},\n\t\ttableHeader: {\n\t\t\tbold: true,\n\t\t\tfontSize: 10,\n\t\t\tcolor: 'black'\n\t\t},\n\t\t\tDataTable: {\n\t\t\tbold: false,\n\t\t\tfontSize: 10,\n\t\t\tcolor: 'black'\n\t\t},\n\t\t\tquote: {\n\t\t\titalics: true\n\t\t}\n    \t}\n};\nmsg.filename = '/home/pi/Pictures/pdf/Daily_report10072022.pdf'\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 570,
        "y": 680,
                "e934fe0a.723cc"
        "id": "51da5e06.c7fd",
        "type": "file",
        "filename": "",
        "appendNewline": false,
        "createDir": true,
        "overwriteFile": "true",
        "encoding": "none",
        "x": 890,
        "y": 680,
                "bdc36ecf.c1c4d"
        "id": "bdc36ecf.c1c4d",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1050,
        "y": 680,
        "id": "e934fe0a.723cc",
        "type": "pdfmake",
        "outputType": "Buffer",
        "inputProperty": "payload",
        "options": "{}",
        "outputProperty": "payload",
        "x": 740,
        "y": 680,
                "51da5e06.c7fd"
        "id": "100f8ac.ed83575",
        "type": "function",
        "name": "Select",
        "func": "msg.topic = 'select Plan_Qty, Input_Qty, Finshed_Goods, Fall_off_rate, Productivity, TPT, Total_Tests, pass_count, fail_count, First_Pass, RW_Pass, RW_Pending  from Line1 order by id desc limit 2'\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 190,
        "y": 680,
                "21247992.fef1d6"
        "id": "21247992.fef1d6",
        "type": "mysql",
        "mydb": "e3e96a2f.4a4ed8",
        "x": 360,
        "y": 680,
                "8ba699c1.0f9858"
        "id": "e8cd8b56.0e0908",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 60,
        "y": 680,
                "100f8ac.ed83575"
        "id": "e3e96a2f.4a4ed8",
        "type": "MySQLdatabase",
        "host": "127.0.0.1",
        "port": "3306",
        "db": "trial_03072021",
        "tz": "",
        "charset": "UTF8"
When I manually define the variables and call them at Table body (as shown in commented rows), this works well. But I cannot do this for all the rows. Reason: 1. High number of rows. 2. Rows count can vary .
I need help to write some loop query or so, so that I can get all the data from mysql to pdf report.
Please suggest.
Please supply demo data (instead of exporting a flow with a mySQL node - since no one on this forum will have your data or access to your database!)
  1. add a debug
  2. copy the data using "copy value"
    chrome_FnQglyo3Bk
  3. paste it into a reply using the forums code </> button (paste copied data into the code block)
I suggest you add the lines after you create the payload, you can push the arrays to the table body.
[{"id":"e8cd8b56.0e0908","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"one\":1,\"two\":2,\"three\":3},{\"one\":1,\"two\":2,\"three\":3},{\"one\":1,\"two\":2,\"three\":3}]","payloadType":"json","x":190,"y":1320,"wires":[["8ba699c1.0f9858"]]},{"id":"8ba699c1.0f9858","type":"function","z":"bf9e1e33.030598","name":"Table format","func":"//datetime\nvar time = new Date().toLocaleString(\"de\");\n\nlet payload = {\n    pageOrientation: 'portrait',\n\tcontent: [\n\t   \t\t\t{\n\t\t\t    columnGap: 20,\n            columns: [\n               {\n\t\t\timage: msg.pellogo,\n\t\t    fit: [75, 75],\n\t\t\talignment: 'left'\n\t\t},\n\t\t\t\n\t\t\t{text: 'Daily Report _ Production', \n\t\t\t\tstyle: 'header',\n\t\talignment: 'center',\n\t\twidth: 300,\n\t\tmargin: [0,0,20,0]\n\t\t},\n\t\t\n\t\t{\n\t\t\timage: msg.stlogo,\n\t\t\tfit: [50,50],\n\t\t\talignment: 'right'\n\t\t},\n\t\t\n\t\t\t]\n\t\t\t},\n'\\n\\n',\n'Key Parameters for all Lines:',\n'\\n\\n',\n\t\t{\n\t\t\tstyle: 'DataTable',\n\t\t\talignment: 'center',\n\t\t\ttable: {\n\t\t\t    headerRows: 1,\n\t\t\t     fontSize: 7,\n\t\t\t\tbody: [\n\t\t\t\t\t[{text:'Line No', style: 'tableHeader'}, {text:'Plan Qty', style: 'tableHeader'}, {text:'Input Qty', style: 'tableHeader'}, {text:'Finshed Goods', style: 'tableHeader'} , {text:'Fall Off Rate', style: 'tableHeader'} , {text:'Productivity', style: 'tableHeader'}, {text:'Throughput Time', style: 'tableHeader'}, {text:'Total Tests', style: 'tableHeader'}, {text:'Pass Count', style: 'tableHeader'}, {text:'Fail Count', style: 'tableHeader'}, {text:'First Pass', style: 'tableHeader'}, {text:'R/W Pass', style: 'tableHeader'}, {text:'R/W Pending', style: 'tableHeader'}],\n\t\t\t\t]\n\t\t\t}\n\t\t},\n'\\n\\n',\n'\\n\\n',\n'Line 5 - Daily Production Trend - Last 7 Days',\n\t\t\t{\n\t\t\timage: msg.image2,\n\t\t\tfit: [400,225],\n\t\t\talignment: 'center'\n\t\t},\n'\\n\\n',\n'Line 5 - FOR Analysis',\n\t\t\t{\n\t\t\timage: msg.image3,\n\t\t\tfit: [200,200],\n\t\t\talignment: 'center'\n\t\t},\n\t\t\t\n    ],\n    \tstyles: {\n\t\theader: {\n\t\t\tfontSize: 18,\n\t\t\tbold: true,\n\t\t\tmargin: [0, 0, 0, 10]\n\t\t\t\n\t\t},\n\t\tsubheader: {\n\t\t\tfontSize: 16,\n\t\t\tbold: true,\n\t\t\tmargin: [0, 10, 0, 5]\n\t\t},\n\t\ttableExample: {\n\t\t\tmargin: [0, 5, 0, 15],\n\t\t\talignment: 'right'\n\t\t},\n\t\ttableHeader: {\n\t\t\tbold: true,\n\t\t\tfontSize: 10,\n\t\t\tcolor: 'black'\n\t\t},\n\t\t\tDataTable: {\n\t\t\tbold: false,\n\t\t\tfontSize: 10,\n\t\t\tcolor: 'black'\n\t\t},\n\t\t\tquote: {\n\t\t\titalics: true\n\t\t}\n    \t}\n};\nmsg.payload.forEach((obj,index) => {\n    let output =[`line${index+1}`];\n    Object.values(obj).forEach(val => output.push(val));\n    payload.content[4].table.body.push(output)\n})\nmsg.payload = payload;\nmsg.filename = '/home/pi/Pictures/pdf/Daily_report10072022.pdf'\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":580,"y":1340,"wires":[["e06e7e50.46ed48"]]},{"id":"e06e7e50.46ed48","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":580,"y":1460,"wires":[]}]
I do not have your data, so you may have to edit the code to fit your data, if you do not require all properties from the msg.payload objects.
I rename the msg.payload to payload so as to not overwrite msg.payload
Dear E1cid,
Thanks a lot. It worked like magic. Everything works as expected.
As I am new to JavaScript, I have to go through all the lines very thoroughly to understand how it works so that I can use this at many other places where I need similar behavior.
Thanks !! This forum is best one due to great contributors like you..
Thanks Steve for your reply. I got the solution from E1cid.
