Get Error For Editing Array In Some Condition
Hi All,
I'm trying to create a function to concatenate array data with various conditions. But the result is not what I expected. I've tried issuing node.warn on the variable that outputs several conditions, but there is the following error:
Here is the code that I use:
var a = msg.payload[0]; //date
var b = Number(msg.payload[1])/1; //count
var c = msg.payload[2]; //load
var c2={} ;
if ( b < 10){
     c2 = c * 2  ;
     return c2;
} else if ( 10 < b < 20)
    c2 = c *1.5;
    return c2;
} else if ( 20 < b < 30)
    c2 = c*1.2;
    return c2;
} else {
    c2 = c;
    return c2;
node.warn("c2");
var d = msg.payload[3];
var e = msg.payload[4];
var f = msg.payload[5];
var g = msg.payload[6];
const SENSORS=[a,b,c2,d,e,f,g];
msg.payload=SENSORS;
Maybe some of you can help me. I really appreciate your help in advance. Thank You
You are returning a number instead of the msg
I suspect you should take out all the return c2 statements.
My Mistakes... Thank you Steve and Colin..
