Get payload back and refresh page after button click
Hello Together,
I am trying to generate a payload in a template-node with a single button and refresh the complete page. I need to do this to load a new header....
But unfortunately I'm a little bit on the tube right now.
Can you help me?
All (button, reload, send message) done in a template node should be something like this:
        "id": "4b2da0b58064d643",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "67e5a02dc04c0c98",
        "type": "ui_template",
        "z": "4b2da0b58064d643",
        "group": "d921e9fe7b208126",
        "name": "My Button",
        "order": 3,
        "width": "6",
        "height": "2",
        "format": "<style>\n    .custom-button{\n        color:white!important;\n    }\n    \n</style>\n<button id=\"MyReloadButton\" class=\"custom-button md-raised md-button md-ink-ripple\" type=\"button\" ng-click=\"OnButtonClick($event)\" aria-label=\"refreshbutton\">\n    <ui-icon ng-show=\"true\" icon=\"mi-refresh\" aria-hidden=\"false\">\n        <div ng-if=\"iconType==='mi'\" style=\"display:inline-block; margin:auto; line-height:initial;\">\n            <i class=\"material-icons mi-refresh\" ng-class=\"icon\">mybutton</i>\n        </div>\n    </ui-icon>\n    <span>Refresh</span>\n</button>\n\n<script>\n    (function(scope) {\n\n        scope.InjectRipple = function() {\n            const buttoninjector = angular.element('#MyReloadButton').injector();\n            buttoninjector.invoke(scope.AttachReloadbuttonToRipple,null,null);\n        };\n        scope.AttachReloadbuttonToRipple = function($mdInkRipple){\n            $mdInkRipple.attach(scope, angular.element('#MyReloadButton'), { center: false });\n        }\n        scope.OnButtonClick = function(evt){\n            switch(evt.currentTarget.id){\n                case \"MyReloadButton\":\n                    const someMessage = 'reload right now!';\n                    scope.send({payload: someMessage});\n                    window.location.reload();\n                break;\n                default:\n                    break;\n            }\n        }\n        scope.InjectRipple();\n        \n    })(scope);\n</script>",
        "storeOutMessages": true,
        "fwdInMessages": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "nr-dashboard-button _md styled-button styled-template",
        "x": 1140,
        "y": 320,
                "c8aaf3986a4c622c"
        "id": "c8aaf3986a4c622c",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1440,
        "y": 320,
        "id": "d921e9fe7b208126",
        "type": "ui_group",
        "name": "Buttons",
        "tab": "d0d82445ef65a632",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "d0d82445ef65a632",
        "type": "ui_tab",
        "name": "ButtonDesign",
        "icon": "dashboard",
        "order": 3,
        "disabled": false,
        "hidden": false
thanks, works fine for me
to put an delay of 2000 ms you could do:
... setTimeout(()=>{window.location.reload();}, 2000); ...
