[{"id":"f73bbce9.98ce6","type":"tab","label":"Loop with IO Status","disabled":false,"info":""},{"id":"498c6c69.672984","type":"function","z":"f73bbce9.98ce6","name":"Simple array","func":"var StrIO = msg.payload // String from Netiom 16 characters long\n\n\n/////Run the loop\n\nvar i;\n\nlet Temp = [];\nlet T = [];\n \nfor (i = 0; i < StrIO.length; i++) {\n\n/////////////////////////////////////////////////////////\n\n\n\n Temp[i]='Tempin'+i; \n T[i]='T'+i; \n\nTemp[i] = context.get(T[i]);\nif (Temp[i] === undefined){\ncontext.set(T[i], \"0\");\n}\nTemp[i] = context.get(T[i]);\n \n \n\n// New trigger\nif (Temp[i] === \"0\" && StrIO[i] === \"1\") {\n\n context.set ('T100', \"0\");\n context.set(T[i], \"1\"); // new\n context.set ('ID', [i]);\n //\n //Reset of trigger\n \n \n \n } else if (Temp[i] === \"1\" && StrIO[i] === \"0\"){\n\n context.set ('ID', [i]);\n context.set ('T100', \"1\");\n context.set(T[i], \"0\");\n Temp[i] = context.get(T[i]);//Reset\n context.set ('ID', [i])\n \n \n}\n \nelse if (Temp[i] === \"0\" && StrIO[i] === \"0\"){\n\n { continue; }\n \n}\n\n\nelse if (Temp[i] === \"1\" && StrIO[i] === \"1\"){\n\n { continue; }\n \n}\n\n\n\n\n\n\n\n\nvar out = {payload: \"Device ID = \" + [i] + \" \" + Temp[i] + StrIO[i] }\n\n\nnode.send({payload: out});\n\n \n///////////////////////////////////////////////////////////////// \n \n }\n \n \n\n\n\n\n\n\n\n\n \n\n\n\n\n\n","outputs":1,"noerr":0,"x":350,"y":300,"wires":[["2d9f9409.018abc"]]},{"id":"8a555f4c.63a4f","type":"inject","z":"f73bbce9.98ce6","name":"","topic":"","payload":"0000000000000000","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":260,"wires":[["498c6c69.672984"]]},{"id":"a3dd4a85.ad3638","type":"inject","z":"f73bbce9.98ce6","name":"","topic":"","payload":"1111111111111111","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":320,"wires":[["498c6c69.672984"]]},{"id":"2d9f9409.018abc","type":"debug","z":"f73bbce9.98ce6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":550,"y":400,"wires":[]},{"id":"8117de1f.29779","type":"comment","z":"f73bbce9.98ce6","name":"This simple array output creates a sql string that i feed into a node-mssql (Changed to a shorter output for the purpose of help)","info":"","x":900,"y":60,"wires":[]},{"id":"c55ff86d.1b1178","type":"comment","z":"f73bbce9.98ce6","name":"I use the following in my function to output the data","info":"","x":670,"y":100,"wires":[]},{"id":"da8b25b6.3fa5b8","type":"comment","z":"f73bbce9.98ce6","name":"var out = {payload: \"Device ID = \" + [i] + \" \" + Temp[i] + StrIO[i] }; ","info":"","x":710,"y":140,"wires":[]},{"id":"2cbaddc1.74a032","type":"comment","z":"f73bbce9.98ce6","name":"node.send({payload: out});","info":"","x":590,"y":180,"wires":[]},{"id":"f42db4f.d81bf48","type":"comment","z":"f73bbce9.98ce6","name":"Using this output way fails to inject into SQL as the debug shows The msg.payload is showing as object","info":"","x":830,"y":220,"wires":[]},{"id":"facd9243.19e9a","type":"comment","z":"f73bbce9.98ce6","name":"10/11/2020, 12:19:26node: 57171b15.b5d274 msg.payload : Object { payload: \"Device ID = 10 00\" }","info":"","x":820,"y":280,"wires":[]},{"id":"4b89d7c5.e2c558","type":"comment","z":"f73bbce9.98ce6","name":"Where as if I used a insert and create a msg.payload it reports as msg.payload string and this populates the data base.","info":"","x":880,"y":340,"wires":[]}]
Your function node is sending a message that has the following structure:
msg = {
payload: {payload:"Your String"}
In this way, your message payload is equal to the following Object:
To return directly the string, you have to replace
node.send({payload:out}
with
node.send(out)
Good Afternoon
I just wanted to thank you for you help not only did it work instantaneously but it has saved be stopping up for a third night, I really do struggle with the whole payload message part of node red, your explanation was very intuitive.
Again thank you
Regards
Andrew
