Getting undefined error in flow.get
i work with flow.get and global.get a lot
however i get an error in the currrent flow but do not see anything wrong
de output is undefined but it should state up (the value of network.192.168.1.25.ipstate
i suspect that the ipaddress having dots is causing the problem but how to solve this
flow including function
[{"id":"88454dc9.c905c","type":"inject","z":"b26f44fa.693c68","name":"","topic":"","payload":"192.168.1.25","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1800,"wires":[["2bee791b.798fe6"]]},{"id":"dab0419c.cded2","type":"debug","z":"b26f44fa.693c68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":750,"y":1800,"wires":[]},{"id":"2bee791b.798fe6","type":"change","z":"b26f44fa.693c68","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":1800,"wires":[["62491705.0074d8"]]},{"id":"62491705.0074d8","type":"function","z":"b26f44fa.693c68","name":"","func":" var ip = msg.topic;\n var status = flow.get('network.'+msg.topic+'.ipstate')\n msg.payload = status\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":1800,"wires":[["dab0419c.cded2"]]}]
data in flow
Here you are:
status = flow.get('network')[msg.topic]["ipstate"];
The problem comes because you are trying to use 192.168.1.25 as part of the key name.
The full key you function code generates is
which results in:
'network.192.168.1.25.ipstate'
It doesn't recognise 192.168.1.25 as a single key name, rather it interprets that as the four distinct object property levels.
The fix is to either generate a key like:
'network["192.168.1.25"].ipstate'
using:
'network["'+msg.topic+'"].ipstate'
or as @techraf suggests, get the whole network object first and then pull out the bits you need.
thanks, almost tried everything (including using ) but sometimes i just can not get it right.
