Hi all,
is there a way to insert a global or flow variable concatenated to a string in this field?
the watch node does not have an input from which to send the filename
The screenshot is perhaps more explicative
No. The watch node is initialised to monitor the file(s) at instantiation and therefore uses a fixed value. for example, if this were possible, it would not know that a global has changed & would not know to start watching another directory.
You have 2 relatively simple options...
${WATCH_FOLDER}
