Good and recent graph package?
I have been running Node Red for several years now, mostly to connect systems in a controlled way and to run logic.
Now I want to get started with graphs, and I found there are several node packages.
Which one is good for me to get started?
Assuming that you mean charts (graphs are something different) then the easiest way is probably to use @flowfuse/node-red-dashboard. Getting Started | Node-RED Dashboard 2.0
Any of them should work. But really we need to understand how you want to present the UI to the users.
You have a few choices (I'm assuming that you want to present the charts on a web page).
  • http-in/http-response node pairs - presents raw ExpressJS web service. You have to do everything yourself.
  • Dashboard 1. Not recommended as it is end of life.
  • Dashboard 2. Great for getting started and has just implemented eCharts - good for simple charts - may get complex if your charts and processing start to get more complex as the use of Vue/Vuetify frameworks may end up just getting in the way.
  • UIBUILDER for Node-RED. Proves a complete way to integrate between Node-RED and your client users. But currently doesn't have a dedicated chart component. However, there are examples for various charting tools and you can literally use any charting library.
I would recommend using either eCharts or ObservableHQ's Plot libraries:
  • ECharts for normal stuff
  • ObserverHQ Plot for more complex and analytical needs
