Gpio(d) - gpiomon - possible speed problem
Hi everybody!
I am trying to capture a digital signal (hall-signal) with an maximum Freqency of 160Hz (tik every 6ms) over a gpio of an android C4 . It is a speed signal from a classic tachometer of a car.
I am gathering the basis data with an exec node running:
gpiomon -b -r -l gpiochip0 70
delivering that
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.916729293]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.922985595]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.929242813]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.935498823]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.941755500]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.948014135]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.954268519]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.960525237]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.966789456]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.973042299]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.979301184]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.985550360]|
|event:|RISING|EDGE|offset:|70|timestamp:|[|4874.991809037]|
Following out logging tests (writing out to a file with a file node, there is nothing of data lost even up to 300Hz.
However, although I know that I should not deal that as string but a I just cannot avoid a .substring statement to get that timestamp isolated here! I consider that as the first big performance trap. If so how to avoid that?
My first asset was then to declare a counter in a function node which counts the ticks / timespan.
Turned out that the counter could not follow the ticks fast enough in order to calculate speed higher than 50km/h (~40Hz, tick every 25 ms).
In terms of qualitiy of the signal: mean while I run a frequency generator to fake the tachometer signal in door - both the tachometer of the car itself and the signal generator result in the same outcome @ nodered:
My second asset (flow attached) was to use an array, fill it up with the payloads and do the same like above but with array.length, so avoid counting.
But also at ~40Hz I cannot write fast enough in the array obviouly, which led me finally to the same crappy result.
Please see my latest flow (below).
[{"id":"4788c8134ed09947","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"402a5383db5006b2","type":"exec","z":"4788c8134ed09947","command":"gpiomon -r -b gpiochip0 70","addpay":"","append":"","useSpawn":"true","timer":"","winHide":false,"oldrc":false,"name":"","x":400,"y":520,"wires":[["f30db6a458de8e99","4acdc22d90eae667"],["d3158db9d08fa6de"],["5b53c3878b668d37"]]},{"id":"ce6fee17b2401b8f","type":"inject","z":"4788c8134ed09947","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"timestamp","v":"","vt":"date"},{"p":"arr","v":"","vt":"num"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"rising","payload":"0","payloadType":"str","x":140,"y":520,"wires":[["402a5383db5006b2"]]},{"id":"f30db6a458de8e99","type":"debug","z":"4788c8134ed09947","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":450,"y":460,"wires":[]},{"id":"4acdc22d90eae667","type":"function","z":"4788c8134ed09947","name":"parse","func":"\nvar array_length = \"0\";\nvar Newmsg = {array:0};\nvar array_timespan = 0; \nvar previous_arr_last_object = flow.get(\"previous_arr_last_object\").toString().substring(1,19);\nvar OpenSwitch = 1;\nvar CloseSwitch = 0; \n\n// beachte \"START\" von diesem Funktion Node!\n\nmsg.Switchnode = CloseSwitch; \n\nmsg.payload = msg.payload.substring(42,62);\n\nNewmsg.array= flow.get(\"arr\");\n\n\n//only add payloads to an non-empty array, which more than < \"TachoLimitFreq\" (ms) apart\nif (msg.topic == \"rising\" && Newmsg.array.length > 0 && (Number(msg.payload.substring(1,19)) - Number((Newmsg.array[Newmsg.array.length-1]).substring(1,19)))*1000 > global.get(\"TachoLimitFreq\"))\n{\n    flow.get(\"arr\").push(msg.payload);\n\n    flow.set(\"arr\", flow.get(\"arr\"));\n    \n    Newmsg.array= flow.get(\"arr\");\n}\n\n\n//only add payloads to an empty array, which more than < 6ms apart from the previous_arr_last_object\nif (msg.topic == \"rising\" && Newmsg.array.length == 0 && (Number(msg.payload.substring(1,19)) - Number(previous_arr_last_object))*1000 > global.get(\"TachoLimitFreq\"))\n{\n    flow.get(\"arr\").push(msg.payload);\n\n    flow.set(\"arr\", flow.get(\"arr\"));\n    \n    Newmsg.array= flow.get(\"arr\");\n}\n\n//Reset nach \"TachoSampleRate\" und speed berechnen\nif( msg.topic == \"reset\" )\n{ \n    Newmsg.array = flow.get(\"arr\");\n  \n    //setze previous_arr_last_object auf den Wert von actual_arr_last_object\n    \n    if (Newmsg.array.length > 0)\n    {\n        flow.set(\"previous_arr_last_object\", Newmsg.array[Newmsg.array.length-1]);\n    }\n    else\n    {\n        flow.set(\"previous_arr_last_object\", 0);   \n    }\n    \n    //bestimme Anzahl der Ticks durch Array_length\n    array_length = flow.get(\"arr\").length.toString();\n    \n    //bestimme array-timespan in s\n    array_timespan = 1, //(Number((Newmsg.array[Newmsg.array.length-1]).substring(1,19)) - Number((Newmsg.array[0]).substring(1,19)));\n    \n    msg.SwitchNode = OpenSwitch;\n    speed = ((20 / 17) * array_length / array_timespan) + (60 / 17);\n    if (speed <= 60 / 17)\n    {\n        msg.speed = 0;\n        //msg.speed = NewMsg.speed;\n    }\n    else\n    {\n        msg.speed = Math.round(speed);\n        //msg.speed = NewMsg.speed;\n    }\n    \n    Newmsg.array.length = 0;\n    flow.get(\"arr\").length = 0;\n    flow.set(\"arr\", flow.get(\"arr\"));\n    \n}\n\nmsg.arr = flow.get(\"arr\"); \nreturn msg;","outputs":1,"noerr":0,"initialize":"// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"arr\", []);\nflow.set(\"previous_arr_last_object\", 0);\n","finalize":"","libs":[],"x":790,"y":500,"wires":[["1591ac925c5f74ec","cb393bac6d87b676"]]},{"id":"1591ac925c5f74ec","type":"debug","z":"4788c8134ed09947","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":600,"wires":[]},{"id":"d3158db9d08fa6de","type":"debug","z":"4788c8134ed09947","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":630,"y":540,"wires":[]},{"id":"5b53c3878b668d37","type":"debug","z":"4788c8134ed09947","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":430,"y":580,"wires":[]},{"id":"c1da860091466f03","type":"inject","z":"4788c8134ed09947","name":"","props":[{"p":"topic","vt":"str"},{"p":"timestamp","v":"","vt":"date"},{"p":"arr","v":"","vt":"num"},{"p":"arrlength","v":"","vt":"num"},{"p":"payload"},{"p":"SwitchNode","v":"0","vt":"str"},{"p":"speed","v":"","vt":"num"}],"repeat":"${TachoSampleRate}","crontab":"","once":false,"onceDelay":0.1,"topic":"reset","payload":"0","payloadType":"str","x":640,"y":380,"wires":[["4acdc22d90eae667"]]},{"id":"73bc008fe77dbdcf","type":"debug","z":"4788c8134ed09947","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1190,"y":420,"wires":[]},{"id":"cb393bac6d87b676","type":"switch","z":"4788c8134ed09947","name":"Moving","property":"SwitchNode","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1000,"y":500,"wires":[["73bc008fe77dbdcf","5df098d4be0d6d10"],["d4a6eb72fbb9e91b"]]},{"id":"d4a6eb72fbb9e91b","type":"debug","z":"4788c8134ed09947","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1190,"y":560,"wires":[]},{"id":"5df098d4be0d6d10","type":"link out","z":"4788c8134ed09947","name":"Tachosignal -->Balckbox_to_MySQL_insert_Velocity","mode":"link","links":["616a5d227d0d8ef5","5cda5648b888f4c2"],"x":1155,"y":460,"wires":[]}]
So can please somebody give me any tips how to improve performance here, as I do not know enough about that, but that my hardware is capeable of doing obviously up to 300 Hz.
How to improve Java code of function node?
kind regards HABAKUK
Nobody having a solution for this?
Is there a general recommendation for reading fast signals over gpio?
greetz
Habakuk
