GPIO state crazy?
Hello friends,
I installed at my Rasperry 3B+ a 8 chanel relay card.
Standard relay, not any SSR.
on the Relay card is a LED for each relay - state LED. I think you know that.
If the Pi is off, the relay is off. If I start the pi and Nodered starts, the Relay is activ (LED is on and Relay closed).but in my Nodered I can see there is a 0 (zero) as GPIO state.
If I press to activate the relay, the LED goes off.
This is revered.
I don´t know where is my failure.
Can somebody support me?
Installed node: node-red-node-pi-gpio
[{"id":"1bd00a5b.7e9796","type":"tab","label":"Säureumwälzung","disabled":false,"info":""},{"id":"277fac78.6b7214","type":"rpi-gpio out","z":"1bd00a5b.7e9796","name":"Relay8 GPIO21","pin":"40","set":true,"level":"0","freq":"","out":"out","x":1200,"y":480,"wires":[]},{"id":"a00e4f49.dadbc","type":"inject","z":"1bd00a5b.7e9796","name":"Säureumwälzung täglich um 16:30","repeat":"","crontab":"30 16 * * *","once":false,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":220,"y":420,"wires":[["d0b4e949.15c288"]]},{"id":"6268a7aa.319078","type":"debug","z":"1bd00a5b.7e9796","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":210,"y":240,"wires":[]},{"id":"d0b4e949.15c288","type":"trigger","z":"1bd00a5b.7e9796","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"60","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":450,"y":420,"wires":[["277fac78.6b7214","271b334d.a7153c"]]},{"id":"662236a.76077c8","type":"switch","z":"1bd00a5b.7e9796","name":">15 A Ladestrom","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"15.000","vt":"num"},{"t":"lte","v":"14.999","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":120,"wires":[["17b86286.7d856d"],["5795c302.f1f80c"]]},{"id":"9a643899.cacf68","type":"switch","z":"1bd00a5b.7e9796","name":">30 A Ladestrom","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"30.000","vt":"num"},{"t":"lte","v":"29.999","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":280,"wires":[["2e1440dd.456e7"],["8b03b5e5.791228"]]},{"id":"3921b1fe.54d44e","type":"trigger","z":"1bd00a5b.7e9796","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"60","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":990,"y":120,"wires":[["49f9263a.578538","277fac78.6b7214","eb94fe9d.1b1d1","271b334d.a7153c"]]},{"id":"49f9263a.578538","type":"function","z":"1bd00a5b.7e9796","name":"","func":"if (msg.payload == \"off\")\n\tcontext.state = 0;\nif (msg.payload == \"on\")\n\tcontext.state = 1;\n\nif (context.state == 1)\n{\n\tif (msg.payload == 0)\n\t\treturn msg;\n\telse\n\t\treturn;\n}\nelse\n\treturn;","outputs":1,"noerr":0,"x":800,"y":180,"wires":[["e86f946a.a00ab8"]]},{"id":"94d2e1c8.7fca","type":"switch","z":"1bd00a5b.7e9796","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":750,"y":120,"wires":[["49f9263a.578538","3921b1fe.54d44e"],["49f9263a.578538"]]},{"id":"e86f946a.a00ab8","type":"delay","z":"1bd00a5b.7e9796","name":"Pause 1 h","pauseType":"delay","timeout":"1","timeoutUnits":"hours","rate":"1","nbRateUnits":"","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":940,"y":180,"wires":[["3921b1fe.54d44e","d82af571.a2f1f8"]]},{"id":"b1bebb9a.5621f8","type":"trigger","z":"1bd00a5b.7e9796","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"60","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":970,"y":280,"wires":[["4d881429.64a61c","277fac78.6b7214","73751a82.229be4","271b334d.a7153c"]]},{"id":"4d881429.64a61c","type":"function","z":"1bd00a5b.7e9796","name":"","func":"if (msg.payload == \"off\")\n\tcontext.state = 0;\nif (msg.payload == \"on\")\n\tcontext.state = 1;\n\nif (context.state == 1)\n{\n\tif (msg.payload == 0)\n\t\treturn msg;\n\telse\n\t\treturn;\n}\nelse\n\treturn;","outputs":1,"noerr":0,"x":800,"y":340,"wires":[["c1090c32.34531"]]},{"id":"947bdad1.059af8","type":"switch","z":"1bd00a5b.7e9796","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":750,"y":280,"wires":[["4d881429.64a61c","b1bebb9a.5621f8"],["4d881429.64a61c"]]},{"id":"c1090c32.34531","type":"delay","z":"1bd00a5b.7e9796","name":"Pause 40 min","pauseType":"delay","timeout":"40","timeoutUnits":"minutes","rate":"1","nbRateUnits":"","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":960,"y":340,"wires":[["b1bebb9a.5621f8","21798f15.2af11"]]},{"id":"17b86286.7d856d","type":"trigger","z":"1bd00a5b.7e9796","name":"on","op1":"on","op2":"0","op1type":"str","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":610,"y":120,"wires":[["94d2e1c8.7fca"]]},{"id":"5795c302.f1f80c","type":"trigger","z":"1bd00a5b.7e9796","name":"off","op1":"off","op2":"0","op1type":"str","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":610,"y":160,"wires":[["94d2e1c8.7fca"]]},{"id":"2e1440dd.456e7","type":"trigger","z":"1bd00a5b.7e9796","name":"on","op1":"on","op2":"0","op1type":"str","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":610,"y":280,"wires":[["947bdad1.059af8"]]},{"id":"8b03b5e5.791228","type":"trigger","z":"1bd00a5b.7e9796","name":"off","op1":"off","op2":"0","op1type":"str","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":610,"y":320,"wires":[["947bdad1.059af8"]]},{"id":"eb94fe9d.1b1d1","type":"debug","z":"1bd00a5b.7e9796","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1190,"y":120,"wires":[]},{"id":"d82af571.a2f1f8","type":"debug","z":"1bd00a5b.7e9796","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1170,"y":180,"wires":[]},{"id":"73751a82.229be4","type":"debug","z":"1bd00a5b.7e9796","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1170,"y":280,"wires":[]},{"id":"21798f15.2af11","type":"debug","z":"1bd00a5b.7e9796","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1170,"y":340,"wires":[]},{"id":"ea8f3e0c.fc4eb","type":"link in","z":"1bd00a5b.7e9796","name":"Batterie Ladestrom / Wert von BMV Batteriemonitor","links":["7c4b565d.138a28","f97f2293.0dd"],"x":175,"y":120,"wires":[["662236a.76077c8","9a643899.cacf68","6268a7aa.319078"]]},{"id":"4de663a2.78764c","type":"comment","z":"1bd00a5b.7e9796","name":"Batterie Ladestrom / Wert von BMV Batteriemonitor","info":"","x":230,"y":80,"wires":[]},{"id":"271b334d.a7153c","type":"ui_text","z":"1bd00a5b.7e9796","group":"6282d61a.28e958","order":0,"width":0,"height":0,"name":"","label":"Relais aktiv","format":"{{msg.payload}}","layout":"row-spread","x":1230,"y":580,"wires":[]},{"id":"34317b33.023024","type":"ui_button","z":"1bd00a5b.7e9796","name":"","group":"6282d61a.28e958","order":9,"width":0,"height":0,"passthru":false,"label":"Ralais 60 Sek an","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":770,"y":580,"wires":[["d0b4e949.15c288"]]},{"id":"6282d61a.28e958","type":"ui_group","name":"Pumpe","tab":"9cfaccc0.6acbf","order":2,"disp":true,"width":"6","collapse":false},{"id":"9cfaccc0.6acbf","type":"ui_tab","name":"PV","icon":"dashboard","disabled":false,"hidden":false}]
Thanks Herbert
It is common for relay boards to use the 0 output state to close the relay. That is because the GPIO pulls actively low, but floats up on a pullup resisto, so to energise the photo isolator on the relay card it is usual to use the pulldown to pull current through the opto isolator.
