Gradient in charts
Greetings, I have been using different codes and I have this problem with the colored background when graphing, in the "chart-image" node the background of different colors appears but modifying the code to display it with the "chart" node it doesn't allow me. I appreciate your help.
        "id": "0244f5bb8d1c0b39",
        "type": "inject",
        "z": "d2f356e8.51d6e8",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 150,
        "y": 180,
                "fc6e3273c80a8bc9"
        "id": "fc6e3273c80a8bc9",
        "type": "random",
        "low": 1,
        "high": 10,
        "inte": "false",
        "property": "payload",
        "x": 360,
        "y": 180,
                "030d60255e8bf3e8"
        "id": "030d60255e8bf3e8",
        "type": "ui_chart",
        "group": "e8af5d916c3b74e5",
        "order": 3,
        "width": 0,
        "height": 0,
        "label": "chartp22",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "clickable",
        "x": 600,
        "y": 180,
                "89bf5d54cca0a5f9",
                "055702cb77187ede",
                "139b46b97385edbe",
                "89ad842407e4590c"
        "id": "11070ea0e2cad381",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": "0.2",
        "topic": "",
        "payload": "",
        "x": 150,
        "y": 220,
                "048332d4c0732ab9",
                "06f106499db0c8c0",
                "5926e211bf52243e"
        "id": "eaaf656accd269de",
        "type": "chart-image",
        "width": 500,
        "height": "500",
        "x": 830,
        "y": 220,
                "ab5ed0b5cff3c5dc"
        "id": "ab5ed0b5cff3c5dc",
        "type": "jimp-image",
        "data": "payload",
        "dataType": "msg",
        "ret": "img",
        "parameter1": "",
        "parameter1Type": "msg",
        "parameter2": "",
        "parameter2Type": "msg",
        "parameter3": "",
        "parameter3Type": "msg",
        "parameter4": "",
        "parameter4Type": "msg",
        "parameter5": "",
        "parameter5Type": "msg",
        "parameter6": "",
        "parameter6Type": "msg",
        "parameter7": "",
        "parameter7Type": "msg",
        "parameter8": "",
        "parameter8Type": "msg",
        "sendProperty": "payload",
        "sendPropertyType": "msg",
        "parameterCount": 0,
        "jimpFunction": "none",
        "selectedJimpFunction": {
            "name": "none",
            "fn": "none",
            "description": "Just loads the image.",
            "parameters": []
        "x": 990,
        "y": 220,
                "f22a4b9b935535ec"
        "id": "f22a4b9b935535ec",
        "type": "image viewer",
        "width": "400",
        "data": "payload",
        "dataType": "msg",
        "active": true,
        "x": 1130,
        "y": 220,
        "id": "5926e211bf52243e",
        "type": "function",
        "name": "function 193",
        "func": "msg.ui_control = {\n    options: {\n        elements: {\n            line: {\n                borderWidth: 3,\n                fill:false,\n                spanGaps:true,\n            },\n            point:{\n                radius:1,\n              pointStyle:'circle'  \n            }\n        },\n        legend: {\n            display: false\n        },\n        scales: {\n            xAxes: [{\n                type: 'time',\n                gridLines: {\n                    display:true,\n                    color: \"rgba(255, 0, 0, 0.8)\",\n                    zeroLineColor: \"rgba(0, 255, 0, 0.8)\"\n                },\n                id: 'custom-x-axis',\n                position:'bottom',\n                ticks: {\n                    display : true,\n                }\n            }],\n            yAxes: [{\n                gridLines: {\n                display:true},\n                id: 'custom-y-axis',\n                \n                scaleLabel: {\n                    display: true,\n                    //display: false,\n                    labelString: 'y-axis title'\n                },\n\n            }]\n        },\n        plugins: {\n            datalabels: {\n                backgroundColor:'whitesmoke',\n                //backgroundColor:'red',\n                borderRadius:1,\n                padding:1,\n                align: 'right',\n                anchor: function(context) {\n                    //node.send({debug:{dataindex:context.dataIndex}});\n                    if (context.dataIndex == context.dataset.data.length - 1) {\n                        return 'center';\n                    } else {\n                        return 'end';\n                    }\n                },\n                offset:8,\n                formatter:function(value) {\n                    return value > 0 ? value.toLocaleString() : '';\n                }\n            }\n        }\n    },\n    \n    plugins: [{\n        beforeDraw: function(chart) {\n            const ctx = chart.ctx;\n            const canvas = chart.canvas;\n            const chartArea = chart.chartArea;\n        \n            // Chart background\n            var gradientBack = canvas.getContext(\"2d\").createLinearGradient(0, 250, 0, 0);\n            gradientBack.addColorStop(0, \"rgba(213,235,248,1)\");\n            gradientBack.addColorStop(0.16, \"rgba(213,235,248,1)\");\n            gradientBack.addColorStop(0.17, \"rgba(226,245,234,1)\");\n            gradientBack.addColorStop(0.25, \"rgba(226,245,234,1)\");\n            gradientBack.addColorStop(0.26, \"rgba(252,244,219,1)\");\n            gradientBack.addColorStop(0.5, \"rgba(252,244,219,1)\");\n            gradientBack.addColorStop(0.51, \"rgba(251,221,221,1)\");\n            gradientBack.addColorStop(1, \"rgba(251,221,221,1)\");\n        \n            ctx.fillStyle = gradientBack;\n            ctx.fillRect(chartArea.left, chartArea.bottom,\n              chartArea.right - chartArea.left, chartArea.top - chartArea.bottom);\n        }\n    }]\n};\n\ndelete msg.payload;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 350,
        "y": 220,
                "030d60255e8bf3e8"
        "id": "89ad842407e4590c",
        "type": "function",
        "name": "Vertical Bar Chart",
        "func": "var long = msg.payload[0].data[0].length;\n\nvar lab = [];\nvar dat = [];\n\nfor(var i = 0; i<long; i++){\n    lab[i] = msg.payload[0].data[0][i].x;\n    dat[i] = msg.payload[0].data[0][i].y;\n}\n\nlet m = {\n    type: 'line',\n    options: {\n        title: {\n            display:true,\n            text:'Vertical bar example'\n        },\n        legend: {\n            display:false\n        },\n        chartArea: {\n            backgroundColor: 'white'\n        },\n        scales: {\n            xAxes: [{\n                type: 'time'\n            }]\n        },\n        plugins: {\n            datalabels: {\n                display:true,\n                backgroundColor:'whitesmoke',\n                borderRadius:1,\n                padding:1,\n                align: 'right',\n                anchor: function(context) {\n                    if (context.dataIndex == context.dataset.data.length - 1) {\n                        return 'center';\n                    } else {\n                        return 'end';\n                    }\n                },\n                offset:8,\n                formatter:function(value) {\n                    return value > 0 ? value.toLocaleString() : '';\n                }\n            }\n        }\n    },\n    \n    plugins: [{\n        beforeDraw: function(chart) {\n            const ctx = chart.ctx;\n            const canvas = chart.canvas;\n            const chartArea = chart.chartArea;\n        \n            // Chart background\n            var gradientBack = canvas.getContext(\"2d\").createLinearGradient(0, 250, 0, 0);\n            gradientBack.addColorStop(0, \"rgba(213,235,248,1)\");\n            gradientBack.addColorStop(0.16, \"rgba(213,235,248,1)\");\n            gradientBack.addColorStop(0.17, \"rgba(226,245,234,1)\");\n            gradientBack.addColorStop(0.25, \"rgba(226,245,234,1)\");\n            gradientBack.addColorStop(0.26, \"rgba(252,244,219,1)\");\n            gradientBack.addColorStop(0.5, \"rgba(252,244,219,1)\");\n            gradientBack.addColorStop(0.51, \"rgba(251,221,221,1)\");\n            gradientBack.addColorStop(1, \"rgba(251,221,221,1)\");\n        \n            ctx.fillStyle = gradientBack;\n            ctx.fillRect(chartArea.left, chartArea.bottom,\n              chartArea.right - chartArea.left, chartArea.top - chartArea.bottom);\n        }\n    }],\n  \n    data: {\n        labels:[],\n        datasets: [\n            {\n                label:\"Sample data\",\n                backgroundColor:'rgba(57,97,184,0.8)',\n                //backgroundColor:'#9E0700',\n                data:[]\n            }\n        ]\n    }\n}\n\nm.data.datasets[0].data = dat;\nm.data.labels = lab;\n\nmsg.payload = m;\n\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 630,
        "y": 220,
                "eaaf656accd269de"
        "id": "e8af5d916c3b74e5",
        "type": "ui_group",
        "name": "PRESENTACION",
        "tab": "20eaa9112016b9a1",
        "order": 1,
        "disp": false,
        "width": 23,
        "collapse": false,
        "className": "seccion"
        "id": "20eaa9112016b9a1",
        "type": "ui_tab",
        "name": "CONDITION MONITORING charts",
        "icon": "crop_7_5",
        "order": 1,
        "disabled": false,
        "hidden": false
When overriding the chart options, plugins can't be used cos you don't have any reference to the chart object.
For chart background, there is nothing to configure with options, you can use CSS to make it happen.
Hello, the information you gave me is useful for another application in which I had not been able to advance, I thank you very much for your help.
But for this graph if I need to visualize it in the form of intervals. Do you know a way to make intervals with colors for the graph, that is to say that the value of the "Y" axis when it is between 0 and 4 is green, from 4 to 8 it is yellow and from 8 to 10 it is red ?
Gradient can be done with sharp sections manner. But definitely nothing can be based on values you have in chart. If you make the chart to have constant min and max you then can handpick percentages for gradient stop points. All of course depends on chart element size thus if you have multiple of charts and different sizes, all those need handpick for stop points.
