Graph shapes and single point
I have a sensor which will real-time provide X,Y Coordinates or multiple items. I want to visualize these on a Dashboard 2.0 and I also want to be able to show closed shape Zones on the same visualization. It appears I need to use a Template node. Can these use HTML Canvas tags? I tried but am not getting the drawn items. This works in the W3 School Try It editor. When I view this, however, I do not get the drawn shapes. The Circles would represent the Point, which will move as the sensor reports new coordinates. The Shape (there will be multiple) will remain constant.
What I get on w# Schools Try It
What I get in the Dashboard
    <h1>HTML5 Canvas - Draw a Shape</h1>
    <canvas id="myCanvas" width="200" height="125" style="border:1px solid #000000;">
        Sorry, your browser does not support canvas.
    </canvas>
    <script>
        // Create a canvas
const canvas = document.getElementById("myCanvas");
const ctx = canvas.getContext("2d");
// Define a new path
ctx.beginPath();
// Set start-point
ctx.moveTo(20,20);
// Set sub-points
ctx.lineTo(100,20);
ctx.lineTo(175,100);
ctx.lineTo(20,100);
// Set end-point
ctx.lineTo(20,20);
// Draw it
ctx.stroke();
ctx.beginPath();
ctx.arc(95, 50, 4, 0, 2 * Math.PI);
ctx.stroke();
      var centerX = 75;
      var centerY = 105 / 2;
      var radius = 7;
      ctx.beginPath();
      ctx.arc(centerX, centerY, radius, 0, 2 * Math.PI, false);
      ctx.fillStyle = 'green';
      ctx.fill();
      ctx.lineWidth = 5;
      ctx.strokeStyle = '#003300';
      ctx.stroke();
    </script>
Just a note: I tried this in a Dashboard 1 template node and it worked as expected. Both nodes are in this flow:
[{"id":"5256cc4fbc27859d","type":"ui-template","z":"7aaa3eef0c41b6c8","group":"c9385e59445930f8","page":"","ui":"","name":"","order":0,"width":0,"height":0,"head":"","format":"    <h1>HTML5 Canvas - Draw a Shape</h1>\n\n    <canvas id=\"myCanvas\" width=\"200\" height=\"125\" style=\"border:1px solid #000000;\">\n        Sorry, your browser does not support canvas.\n    </canvas>\n\n    <script>\n        // Create a canvas\nconst canvas = document.getElementById(\"myCanvas\");\nconst ctx = canvas.getContext(\"2d\");\n\n// Define a new path\nctx.beginPath();\n\n// Set start-point\nctx.moveTo(20,20);\n\n// Set sub-points\nctx.lineTo(100,20);\nctx.lineTo(175,100);\nctx.lineTo(20,100);\n\n// Set end-point\nctx.lineTo(20,20);\n\n// Draw it\nctx.stroke();\n\nctx.beginPath();\nctx.arc(95, 50, 4, 0, 2 * Math.PI);\nctx.stroke();\n\n\n      var centerX = 75;\n      var centerY = 105 / 2;\n      var radius = 7;\n\n      ctx.beginPath();\n      ctx.arc(centerX, centerY, radius, 0, 2 * Math.PI, false);\n      ctx.fillStyle = 'green';\n      ctx.fill();\n      ctx.lineWidth = 5;\n      ctx.strokeStyle = '#003300';\n      ctx.stroke();\n\n    </script>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1680,"y":420,"wires":[[]]},{"id":"0234bbe826c64216","type":"inject","z":"7aaa3eef0c41b6c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"<!DOCTYPE html> <html> <body> <h1>HTML5 Canvas - Draw a Shape</h1>  <canvas id=\"myCanvas\" width=\"200\" height=\"125\" style=\"border:1px solid #000000;\"> Sorry, your browser does not support canvas. </canvas>  <script> // Create a canvas const canvas = document.getElementById(\"myCanvas\"); const ctx = canvas.getContext(\"2d\");  // Define a new path ctx.beginPath();  // Set start-point ctx.moveTo(20,20);  // Set sub-points ctx.lineTo(100,20); ctx.lineTo(175,100); ctx.lineTo(20,100);  // Set end-point ctx.lineTo(20,20);  // Draw it ctx.stroke();  ctx.beginPath(); ctx.arc(95, 50, 4, 0, 2 * Math.PI); ctx.stroke();         var centerX = 75;       var centerY = 105 / 2;       var radius = 7;        ctx.beginPath();       ctx.arc(centerX, centerY, radius, 0, 2 * Math.PI, false);       ctx.fillStyle = 'green';       ctx.fill();       ctx.lineWidth = 5;       ctx.strokeStyle = '#003300';       ctx.stroke();  </script>  </body> </html>","payloadType":"str","x":1170,"y":420,"wires":[["5256cc4fbc27859d","07a0c69d7b003f4d"]]},{"id":"07a0c69d7b003f4d","type":"ui_template","z":"7aaa3eef0c41b6c8","group":"08ac9b242ae51e8c","name":"2","order":15,"width":"6","height":"6","format":"    <h1>HTML5 Canvas - Draw a Shape</h1>\n\n    <canvas id=\"myCanvas\" width=\"200\" height=\"125\" style=\"border:1px solid #000000;\">\n        Sorry, your browser does not support canvas.\n    </canvas>\n\n    <script>\n        // Create a canvas\nconst canvas = document.getElementById(\"myCanvas\");\nconst ctx = canvas.getContext(\"2d\");\n\n// Define a new path\nctx.beginPath();\n\n// Set start-point\nctx.moveTo(20,20);\n\n// Set sub-points\nctx.lineTo(100,20);\nctx.lineTo(175,100);\nctx.lineTo(20,100);\n\n// Set end-point\nctx.lineTo(20,20);\n\n// Draw it\nctx.stroke();\n\nctx.beginPath();\nctx.arc(95, 50, 4, 0, 2 * Math.PI);\nctx.stroke();\n\n\n      var centerX = 75;\n      var centerY = 105 / 2;\n      var radius = 7;\n\n      ctx.beginPath();\n      ctx.arc(centerX, centerY, radius, 0, 2 * Math.PI, false);\n      ctx.fillStyle = 'green';\n      ctx.fill();\n      ctx.lineWidth = 5;\n      ctx.strokeStyle = '#003300';\n      ctx.stroke();\n\n    </script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1670,"y":480,"wires":[[]]},{"id":"c9385e59445930f8","type":"ui-group","name":"Chart Examples","page":"0c9c3e89de66aaad","width":"6","height":"1","order":4,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"08ac9b242ae51e8c","type":"ui_group","name":"Default","tab":"2acb95821445c8af","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"0c9c3e89de66aaad","type":"ui-page","name":"Charts","ui":"4c2bb00f7172c414","path":"/charts","icon":"home","layout":"notebook","theme":"5075a7d8e4947586","order":27,"className":"","visible":"true","disabled":"false"},{"id":"2acb95821445c8af","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"4c2bb00f7172c414","type":"ui-base","name":"My 1st 2.0 Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"navigationStyle":"default","titleBarStyle":"default"},{"id":"5075a7d8e4947586","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
First thing of note is that currently we require anything you want to render as HTML to be wrapped in a <template> block, e.g.
<template>
    </canvas>
</template>
Although, even when I've done this, it's still not running as I would expect - I think this is to do without how our event lifecycle works, we render the HTML, but the JS is running before the HTML is fully mounted/ready.
I'm still investigating this, and will update more soon.
As a quick sanity check I made it a bit more "Vue" by doing:
<template>
    </canvas>
</template>
<script>
    export default {
        mounted () {
            // Create a canvas
            ctx.beginPath();
            // Set start-point
            ctx.moveTo(20,20);
            // Set sub-points
            ctx.lineTo(100,20);
            ctx.lineTo(20,100);
            // Set end-point
            ctx.lineTo(20,20);
            // Draw it
            ctx.stroke();
            ctx.beginPath();
            ctx.stroke();
            var centerX = 75;
            var radius = 7;
            ctx.beginPath();
            ctx.fill();
            ctx.lineWidth = 5;
            ctx.stroke();
</script>
which causes the code in our <script> to run once the HTML has been loaded fully, but we shouldn't be forcing users/developers ot have to write in this fashion. Raw JS should still be supported, so I'll work out how we can make that so.
I've made a change in when the generic JS runs, it'll now run as part of the mounted block, meaning that these references will work (I've explicitly tested with your initial code snippet too):
