Group background color
How do I set the background colour for a group? I would like a different colour for each group. I have tried setting 'background-color' in a template, but that only works for the widgets.
If you mean the dashboard 2 group, You can go into edit group via the dashboard 2 sidebar, click edit group, then select create theme, and there you can select the theme colours for the group.
You can then use that theme for the group
Target the v-card in the group with CSS in a CSS All Pages type template. Also, use !important (yes, not cool, but necessary in this case)
div.nrdb-ui-group.pink  div.v-card {
    background-color: pink !important;
div.nrdb-ui-group.lime  div.v-card {
    background-color: lime !important;
div.nrdb-ui-group.cyan  div.v-card {
    background-color: lightcyan !important
First you'll need to add the class names for all your groups where you want to modify CSS
And then write the CSS for page/pages where those groups will live.
Actually many ways to target the group background.
@ Steve-Mcl you have the solution. You add the definitions to the template:
Then in the group Class, you just specify the colour: lime, lightcyan or pink.
Thank you Steve
