Having issues with axios getting and returning data in my custom node
I am trying to use axios to call a URL and return its data. That part is working, but the ordering is not working when used as a function call. I am sure it's something simple, but I am not used to JavaScript.
The code below has two node.warn parts so that I can see what is being returned.
The one in the function node.warn(["Finally", r, e]) shows the correct data, the one after the function call node.warn(["HTTP", httpReq]); is returned first, and shows httpReq as being undefined. It's like the code is not waiting for the function call to execute.
function httpRequest(method, url, headers) {
    var r = null;
    var e = null;
    switch (method) {
        case "GET": {
            axios.get(url)
                .then(response => {
                    r = response.data;
                .catch(error => {
                    e = error;
                .finally(() => {
                    return [r, e];
            break;
        case "POST": {
            node.warn("POST");
            break;
        default: {
            raiseError("No method defined", msg);
            break;
With the function call of
this.on('input', function(msg, send, done) {
    if ((this.action != "Log Off") && (!flow.sid || flow.sid == undefined)) {
        var url = "http://www.example.com"
        var httpReq = httpRequest("GET", url);
    done();
Just a question first - many people who are new to Node Red bring their "old way" of doing things - wondering have you looked at the HTTP request node to do this for you ? i.e. move your code into the visual paradigm or is there a reason this will not work for you ?
Craig
I have a working subflow performing one specific API call but want to expand the functionality to cover more API calls. The only way to do this without it being a massively huge flow is by creating a custom node
Aaah right - fair enough i guess - i personally would still go with inidividual http nodes unless you are talking 100's of api calls
Craig
you are right .. because axios is async it executes in your httpRequest function and then it moves along to the next thing .. which is the break ? it doesnt return anything at that point
maybe it would be better if you return the axios call (which is a Promise)
      switch (method) {
        case "GET": {
          return axios.get(url);
        case "POST": {
          node.warn("POST");
        default: {
          break;
... and then use await and a try catch on the input callback (which needs to be async also)
   this.on("input", async function (msg, send, done) {
      var url = "http://www.example.com";
      try {
        var response = await httpRequest("GET", url);
        var httpReq = response.data;
        node.send({ payload: httpReq });
      } catch (err) {
        node.warn(err);
      done();
This is the nature of the async beast.
Add a callback argument to your httpRequest function & call the callback inside the then and catch (get rid of the two variables & the finally)
Thanks, I'll have a play
