Having problems iterating over array
What am I doing wrong here that gives me this unexpected result
[{"id":"fef7fe8fd4d77d41","type":"inject","z":"b2bde7ab2cd3fea7","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"2cfd92a831314f8b\",\"cheerlights\"]","payloadType":"json","x":390,"y":220,"wires":[["c729996341d595dd"]]},{"id":"5e372b637dfb3df1","type":"debug","z":"b2bde7ab2cd3fea7","name":"debug 377","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":220,"wires":[]},{"id":"c729996341d595dd","type":"function","z":"b2bde7ab2cd3fea7","name":"function 3","func":"var homemadeSub;\nvar count = 0;\n\nhomemadeSub = (msg['payload']);\nfor (var j in homemadeSub) {\n  node.warn('count:' + count);\n  node.warn('j:' + j);\n  count +=1;\n}","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":220,"wires":[["5e372b637dfb3df1"]]}]
FYI I have to use the for (x in array) looping construct as that is what Blocky transcodes to
I think for...in is for key:object.
for arrays, I tend to use incrementing
let homemadeSub;
let count = 0;
homemadeSub = msg['payload'];
for (let i = 0;i<homemadeSub.length;i++) {
  node.warn('j:' + homemadeSub[i]);
  count++;
You can also use forEach
homemadeSub.forEach((v,i) =>{
  /* v - Value */
  /* i - Inxex */
Sorry - you missed the extra info I added to my post
Also, this implies that its perfectly valid
Yup the for...in is only returning the index (the key I would guess)
var count = 0;
var homemadeSub = (msg['payload']);
  node.warn('j:' + homemadeSub[j]);
  count +=1;
Yes - that's what I'm expecting
What I'm not expecting is the extra two wierd runs thru the loop :slight_smile:
How odd - I only get one (with 2 warns each)
I too get neither "pairs" nor "forNestedEach".
What does this mean?
That's what Blockly transcodes
to JavaScript
It does it very verbosely in order to cope with more complex things
I'll try it out on another instance
Well - it too works fine for me on another instance!
I stopped/started NR on the orig and it still gives weird result :confused:
Nodejs version different for instances?
Does it make a difference if you initialise homemadeSub and/or use let instead of var?
let homemadeSub = []
No diff
//var homemadeSub;
var count = 0;
//homemadeSub = ["val1","val2"];
  count +=1;
But if I directly set homemadeSub to ["val1","val2"] it works fine
What about let homemadeSub = msg.payload ? (I don't see any reason why it would make a difference, just that Blockly has generated odd looking code)
Makes no diff unfortunately
Going to set up a new @TotallyInformation alternate instance on the same machine and see what happens with it
[edit]Just re-installing node.js first - made no diff
Alternate install works fine - going to re-install main NR now ...
No diff :frowning: still wierd behaviout)
Starting to look like a nuke from orbit solution might be needed :frowning:
So I've re-installed node.js (18.18.2)
re-installed NR
removed node-modules folder and done npm install
Still not working properly :frowning:
for .. in is not intended for use with Arrays. It iterates over all the properties of the Array, including inherited properties, not just the indexed elements. Possibly something you have installed has extended Array.prototype by adding properties.
Use forEach() as suggested.
I wish I could :slight_smile:
But
So I'm stuck with Blocky transcoding to that syntax and AFAICT it's considered valid JavaScript
And it works for everyone except in this NR instance on this machine
I can work around it by using a different Blocky looping construct but that's just disguising the problem
or..
if(!isNaN(j)){
 // do stuff
But again, that's just hiding the problem
If you temporarily rename your .node-red folder to something else and then restart node-red it will re-create the folder with empty flows and no installed nodes. If you then import your test flow and run it is it ok? If so then it is presumably one of the nodes you have installed, or a library you have imported, causing the problem.
Just be careful when you then delete that folder and rename the original. Possibly make sure your backup of the flows is up to date first.
I'm pretty convinced at this point that it's some contrib node I've loaded that's causing this
So I'm trying to find out a different way
Luckliy, this instance only has 20 flows! so I'm copying the flows one at a time across tpo the alternate instance created earlier and then adding in any contrib nodes they need to run.
Doing the flows I care about 1st :slight_smile:
