Having trouble parsing this message
I have an exec node running some code.
I connect to the return code output. (The bottom one)
This is the message coming out:
{"topic":"DO_THIS","qos":2,"retain":false,"_msgid":"755998b4.052328","payload":{"code":0}}
I open the payload part and copy the value. I'm guessing it is 0.
But when I paste it I get:
0 but it isn't quite that easy.
I put that into a switch node and it never gets through.
Wondering what is going on, I copy the value and paste it.
Things get weird now.
Screen shot time.
This is an arbitrary function node.
Note where the cursor is.
So then I press paste and this is what I get:
Somehow there is a carriage return built into what I copied.
I'm confused.
What is going on?
I can reproduce. It only happens if i copy the value from the debug window or click copy value. If another source is used (vscode/sublime), it does not happen.
There might be an special hidden character. (i couldn't find it).
Phew. It isn't just me.
Ok. Not a big deal. I will work around the problem.
Appreciated you validating it wasn't me doing something stupid.
That suggests you did not do it correctly. Show us what you tried.
show?
I have the debug node, expand the tree to see what I want to get, click on the clipboard icon.
It says copied to clip board.
I then pate it in the function node at the end of the line and the 0 from the clipboard is at the start of the line.
Doesnt happen in Chrome on Windows - might be a browser or OS thing?
I tried with the debug set to show msg.payload AND showing full message - same result.
(How are you doing this magic?) :wink:
Screen recordings.
sharex (windows only)
For linux, there is peek and others though not as feature rich as sharex
Ah, windows.
Not much good for Ubuntu.
Ok, I have word around it by changing the == to contains.
That works.
You said you tried it in a Switch node but it didn't work, but you haven't showed us what you tried in the switch node. Then you went on to talk about a function node problem.
Originally the node was like this:
[{"id":"7f0765ad.dfa1f4","type":"switch","z":"5b95490e.a46ab8","name":"Ok/Error","property":"payload.code","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"127","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1610,"y":690,"wires":[["4fd1597d.7d477"],["9c0f56c2.186e9"]]}]
But works when it is set as:
[{"id":"7f0765ad.dfa1f4","type":"switch","z":"5b95490e.a46ab8","name":"Ok/Error","property":"payload.code","propertyType":"msg","rules":[{"t":"cont","v":"0","vt":"num"},{"t":"cont","v":"127","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1610,"y":690,"wires":[["4fd1597d.7d477"],["9c0f56c2.186e9"]]}]
So I was just curious why the payload isn't as I am copying from the debug node.
I only went into the function node to paste the copied msg.payload to see what node-red thinks of it.
== is working for me.
besides if you put contains not only 0 will pass but 10 , 2022 etc whatever contains zero and that may not be what you want.
you sure you are setting msg.payload.code in the switch node ? and not simply msg.payload ?
Yes, I am sure that is the message structure.
Alas it is an artefact of my early MQTT stuff.
It is the output of an exec node. It only really puts out 0 for good, and 127 for errors.
That is all I want to get from the output.
I think you're on to something.
The fact Andrew states he solved it by using contains instead of == suggest he was comparing to string 0 not number 0
Not that it should matter but payload.code is definitely a number so your example would be the correct solution.
I was suspicious that it was a text, which also lead me to paste it in a function node.
When it was pasted in the node, it was orange so I take it that it is a number.
More like...
Ok. I was talking about the 0 to the left of this is just some text.
But yes: correct.
Is this from o/p 3 of a switch node?
Is the exec node feeding direct into the switch node or is there anything at all in between?
Can you show us the config of the exec node? I want to try and replicate the problem.
I don't even know what "contains" means if the type is number.
Yes, but you copied that from the debug
A 0 in the JS editor is a number because it has no quotes.
The debug does not copy " quotes so a string "0" zero would copy and paste as 0
In other words, pasting the value means nothing - how its presented in the object is what matters.
in other words, it IS / WAS a number so use the == number in the switch (not contains)
No, via a delay node set to delay the message for 5 seconds.
