Heatmap - only update changed values
I build a heatmap to monitore temperatures and CO2 values on a floor plan image.
By design, the Heatmap Node displays a given Matrix which works like a charm.
My sensors send their data via MQTT in different sample rates.
I'm using a function to build the heatmap matrix
var T1 = msg.payload.U10_T1;
var T2 = msg.payload.U10_T2;
msg.payload =
    T1, T2
Because messages for T1 and T2 are asynchron, mostly one of both is null.
Does anyone has an idea, how to keep the values of T1 and T2 until they change?
This would give me the possibility to display values of different sample rates on my heatmap.
Thank you :slight_smile:
Martin
What should happen the first time one of the readings comes - say T1, but T2 has never come in?
It doesn't matter. They can use a default like any number. This is where I stuck buildung an if statement which checks for new data.
I didn't find a way to initialize variables and set them to a number value.
I got it working
var T1_temp = context.get('T1_temp')||1;
var T2_temp = context.get('T2_temp')||2;
if (T1 === undefined) {
   T1 = T1_temp;
   context.set('T1',T1_temp);
else {
    T1_temp = T1;
    context.set('T1_temp',T1);
if (T2 === undefined) {
   T2 = T2_temp;
   context.set('T2',T2_temp);
else {
    T2_temp = T2;
    context.set('T2_temp',T2);
msg.payload =
    T1, T2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
But I think I need to learn something about callbacks. This seems to be a much nicer way...
Hi Martin,
I have not tried it, but - out of my head - can't you shorten it to something like this:
var T1 = msg.payload.U10_T1||context.get('T1')||1;
var T2 = msg.payload.U10_T2||context.get('T2')||2;
context.set('T1',T1);
context.set('T2',T2);
I mean: first try to get it from the message, then try to get it from context memory, and otherwise use a default value?
Bart
This is fantastic!
Thank you so much! :star_struck:
