Hello How to turn on UI LED with buffer data value?
hello
as shown in the picture
Calculate the buffer data as a number
I'm trying to turn on the UI LED with a value of 52488.
What should I do?
Thank you for your interest.
If you open the ui-led node, what does it say it needs to turn the led on and off?
The buffer value in the function node was converted to an int value.
The value is 524288.
true if this value is 524288
Otherwise, if it is any other value, set to false.
I want to express it, but what node should I use?
I'd like to know if there is another way.
Thank you for your sincere interest.
You can probably do it with a switch node
and then two change nodes
In the function node you could test it and return true or false
Removed uibuilder tag as this isn't about uibuilder.
thank you very very much ~.~!!!!
thank you very very much ^.^~!!!!
thank you very very much . !!!!
