So I just refreshed my SD card using 2022-04-04-raspios-bullseye-armhf.img and put it in a Raspberry Pi 3 Model B. Then I did:
sudo apt update
sudo apt full-upgrade
I then installed NR using the script and created the following flows
[{"id":"27d6cae76dfbbdb1","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"1b0e2ed279b9c88d","type":"exec","z":"27d6cae76dfbbdb1","command":"pactl -- set-sink-volume 0 20%","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"","x":590,"y":180,"wires":[["a5c3cde7f06df862"],["c4bcd1215151f359"],["067fd8c0894758ca"]]},{"id":"8e948c825a7ab298","type":"inject","z":"27d6cae76dfbbdb1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":180,"wires":[["1b0e2ed279b9c88d"]]},{"id":"c4bcd1215151f359","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":180,"wires":[]},{"id":"a5c3cde7f06df862","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":140,"wires":[]},{"id":"067fd8c0894758ca","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":220,"wires":[]},{"id":"036d47456cf6d7d4","type":"exec","z":"27d6cae76dfbbdb1","command":"amixer set Master 70%","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"","x":570,"y":380,"wires":[["fbb12fd84db39755"],["c609af3bea6d77db"],["4cd2c4281e32f5be"]]},{"id":"ec1811a29e1a2f54","type":"inject","z":"27d6cae76dfbbdb1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":380,"wires":[["036d47456cf6d7d4"]]},{"id":"c609af3bea6d77db","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":380,"wires":[]},{"id":"fbb12fd84db39755","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":340,"wires":[]},{"id":"4cd2c4281e32f5be","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":420,"wires":[]},{"id":"cf53559376404d84","type":"catch","z":"27d6cae76dfbbdb1","name":"","scope":null,"uncaught":false,"x":420,"y":60,"wires":[["ac9e9794d0c0c914"]]},{"id":"ac9e9794d0c0c914","type":"debug","z":"27d6cae76dfbbdb1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":60,"wires":[]}]
I now have the RPI3 dashboard showing on Monitor 1 and I have a Mac with another monitor accessing NR from the RPI3. When I press the two injects, I see the volume slider on the Pi Desktop move up and down. So it is working fine for me. Try the flow I provided.
If it doesn't work there is something different between how I am doing things and how you are.
Are you accessing NR using the monitor/keyboard connected on the Pi or a different computer?
Do you have more than one user defined on the Pi?
