HELP, I don't know what variable to send to node md5-file
I use this node
msg.filepath = ``; with directory but don't work
No such file or directory
        "id": "9e0822ba05e4d42d",
        "type": "md5.file",
        "z": "b733adccca0e0554",
        "name": "trigger.txt",
        "filepath": "",
        "hashField": "md5",
        "x": 520,
        "y": 1340,
                "759c389c2304de12"
        "id": "759c389c2304de12",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 740,
        "y": 1340,
        "id": "5d055539f864b3e5",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "str",
        "x": 230,
        "y": 1340,
                "653615c339614e35"
        "id": "653615c339614e35",
        "type": "function",
        "func": "msg.filepath = 'C:\\\\Users\\\\dumitru.maros\\\\.node-red\\\\doc\\\\trigger.txt'\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 1340,
                "9e0822ba05e4d42d"
I guess the obvious thing would be to double-check that the file really is in that position :slight_smile:
THen I would change the \s to / which Windows is absolutely fine with and avoids all the double \\ malarky.
And I would test without the c: on the front in case the md5 node hasn't been well coded and can't cope with the Windows drive letter on the front.
I think the node md5-file don't read the variable msg.filepath, because i try in linux and same
I found solution
simple import module md5
msg.payload = md5(msg.payload); :smiley: :smiley:
        "id": "8c4804ebaf1b3b5c",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 1520,
                "4cfe8d356f0407f5"
        "id": "e1f1324de713b421",
        "type": "function",
        "func": "msg.payload = md5(msg.payload);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [
                "var": "md5",
                "module": "md5"
        "x": 760,
        "y": 1520,
                "5c3dc5fe300f2a32"
        "id": "5c3dc5fe300f2a32",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 950,
        "y": 1520,
        "id": "4cfe8d356f0407f5",
        "type": "file in",
        "filename": "C:\\Users\\dumitru.maros\\.node-red\\doc\\trigger.txt",
        "format": "",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 460,
        "y": 1520,
                "e1f1324de713b421"
