Help needed for create a delay in a node
I'm new and i need to create a node that send some msg and create a delay of 5 second so when i start the node it need to wait 5 seconds and then send a msg and so on
Is this devoloping a node or creating a flow?
ig is to create a flow.. it's mt first day on nodered
Take a look at the delay node or inject node can have a delay after deploy or restart, Please supply a example flow if you have further issues.
How to import/export a flow
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
[moved topic to general]
the fact is that is like fro school.. and iidk how to explain with precision.. but it's thx for the moment i'll try to figure it out
Also I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
And if you are going to develop a dashboard to show run time data (charts, gauges, text displays and so on) then see Getting Started | Node-RED Dashboard 2.0 for docs and links to video tutorials for Dashboard 2.0 (@flowfuse/node-red-dashboard)
Welcome to the forum @schnre.
Do you want to send a message every 5 seconds, forever? The inject node has an option for this:
If you need a delay of 5 seconds before the first message, take a look at the delay node:
If you need to interrupt the continuous output of messages it is a bit more complicated, but still perfectly doable.
