bwims
21 July 2022 10:48
1
I am migrating a module which I used to use with node-red-contrib-function-npm to the new(-ish) method of specifying the modules in the "Setup" tab of the function node.
If I import the example of node-copy-paste This returns an object with properties which are functions and these work fine.
However, if I import the module I was using, gps-to-gpx , this module exports a function.
I specify it like this
When I attempt to call it as specified in the module description:
const gpx = createGpx(data.waypoints, {
activityName: data.activityType,
startTime: data.startTime,
It fails with the Typedef error that createGpx is not a function.
What am I missing? I'd be grateful for any help!
Put the following in your function - node.warn({ "what-is-this": createGpx })
What do you see in the debug panel?
It is likely you should import gps-to-gpx as gpsToGpx then call gpsToGpx.createGpx
bwims
21 July 2022 11:08
3
Thanks for replying Steve!
I already tried the object idea, but I tried it again per your example:
"TypeError: gpsToGpx.createGpx is not a function"
I'm not strong with coding, but the source code of the module contains this line:
export default function createGpx(waypoints, options = {})
It's weird that the "what-is-this" reports a function, but then it isn't!
As ever, very grateful for the help so far!
Edit:
Apparently "Export Default" is part of ES6 which the release notes for V2 say is supported.
Edit 2:
I noticed another difference between this module and others....
E.g. copy-paste definition states that it is imported like this:
var ncp = require("copy-paste");
ncp.copy('some text', function () {
// complete...
Whereas gps-to-gpx is defined like this:
const createGpx = require('gps-to-gpx').default;
Note the .default at the end of the require.
Is there a way of getting Node Red to import in that way?
Yes, so gpsToGpx.default should do the trick...
const data = {
waypoints: [{ latitude: 51, longitude: -1 }, { latitude: 51, longitude: 0 }, { latitude: 51, longitude:1}],
activityType: "run",
startTime: new Date()
msg.payload = gpsToGpx.default(data.waypoints, {
bwims
21 July 2022 11:31
5
Hooray!
I was so close, too! Thanks very much Steve, you are an absolute hero! (I do regret reaching working age in the 70s instead of the 90s!)
Cheers!
Brian
