Help to define a correct array
Hi. I need help to organise an array in a function node.
  • When datas are valid (flag = A) ... running fine
  • When datas are invalid datas (flag = else) ... wrong split. The additional array wifiAccessPoints can't be cut like it should be, as: ssid, macAddress, signalStrength
Below, only 4 wifiAccessPoints, but it can be really more...
[{"id":"a3659948.e3a2d8","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"808e6dcf.2024e","type":"inject","z":"a3659948.e3a2d8","name":"Valid IWAP01","topic":"","payload":"IWAP01190215A2232.9806N11404.9355E000.1061830323.8706000908000102,460,0,9520,3671#","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":116,"y":114,"wires":[["46808aec.699a04"]]},{"id":"b3d6f3f0.126ee","type":"inject","z":"a3659948.e3a2d8","name":"Invalid IWAP01","topic":"","payload":"IWAP01190215V0000.0000N00000.0000E000.1061830323.8706000908000102,460,0,9520,3671,Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97#","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":126.5,"y":196.00000190734863,"wires":[["46808aec.699a04"]]},{"id":"46808aec.699a04","type":"function","z":"a3659948.e3a2d8","name":"AP01 split flag A/V TOTAL","func":"// flag = A\n//IWAP01080524A2232.9806N11404.9355E000.1061830323.8706000908000102,460,0,9520,3671#\n// flag = else\n//IWAP01080524V0000.0000N00000.0000E000.1061830323.8706000908000102,460,0,9520,3671,Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97# \nlet answer = {}\nlet elements = msg.payload.replace('#','').split(\",\")                                                           // this gives an array containing the bits\n// elements[0] is the long string starting IWAP01\nanswer.command = elements[0].substr(0,6)\nlet dateStr = elements[0].substr(6,6)        // eg \"190215\" 15th Feb 2019\nanswer.date = new Date(Number(dateStr.substr(0,2))+2000, Number(dateStr.substr(2,2))-1, dateStr.substr(4,2))    // 080524 - date\nanswer.valid = (elements[0].substr(12,1) === \"A\")                                                               // true or false - A or V\nif (answer.valid) {\n    let degreesN = Number(elements[0].substr(13,2))\n    let minutesN = Number(elements[0].substr(15,7))\n    let ns = elements[0].substr(22,1)        // N or S\n    let degreesE = Number(elements[0].substr(23,3))\n    let minutesE = Number(elements[0].substr(26,7))\n    let ew = elements[0].substr(33,1)        // E or W\n    node.warn(`${degreesN}  ${minutesN}  ${ns}  ${degreesE}  ${minutesE} ${ew}`)\n    answer.latitude = degreesN + minutesN/60        // 2232.9806N\n    if (ns === \"S\") answer.latitude = -answer.latitude\n    answer.longitude = degreesE + minutesE/60\n    if (ew === \"W\") answer.longitude = -answer.longitude                                                        // 11404.9355E\n} else {\n    answer.latitude = 0\n    answer.longitude = 0\n}\n\nanswer.speedMoving = elements[0].substr(34,5)        // 000.1\nanswer.angleDirection = elements[0].substr(45,6)        // 323.87\nanswer.GSMsignal = elements[0].substr(51,3)        // 060\nanswer.satellites = elements[0].substr(54,3)        // 009\nanswer.batteryLevel = elements[0].substr(57,3)        // 080\n// LBS datas\nanswer.mobileCountryCode = elements[1]        // 460\nanswer.mobileNetworkCode = elements[2]        // 0\nanswer.locationAreaCode = elements[3]        // 9520       \nanswer.cellId = elements[4]        // 3671\n// WIFI bases only with flag = else\n//\n// answer.wifiAccessPoints = elements[5]\n//\nanswer.wifiAccessPoints = []\nif (answer.valid === \"else\") {\n    i = elements[4]+1                 // move on to wifi bases\n    let wifiAccessPointsStrings = elements[5].split(\"&\")\n    let j;\n    for (j=0; j<wifiAccessPointsStrings.length; j++) {\n        let baseElements = wifiAccessPointsStrings[j].split(\"|\")\n        answer.wifiAccessPoints.push({ssid: baseElements[0], macAddress: baseElements[1], signalStrength: baseElements[2]})  // Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97\n    }\n}\n\nmsg.payload = answer\nreturn msg\n\n\n\n","outputs":1,"noerr":0,"x":382.50000762939453,"y":144.00000190734863,"wires":[["8e6852f6.ee3a4"]]},{"id":"8e6852f6.ee3a4","type":"debug","z":"a3659948.e3a2d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":629.5000076293945,"y":144.00000381469727,"wires":[]}]
Someone who can help? Thanks...
Solved! Thanks to all...
it would be good if you could post your solution so that if someone else searches and find this thread it could be useful to them
Right ...
I just did a mistake writing my array and defining my variable "i".
The right solution is :
[{"id":"9b0ef6dd.ce4ec8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"4e5ac99.5724138","type":"inject","z":"9b0ef6dd.ce4ec8","name":"Valid IWAP01","topic":"","payload":"IWAP01190215A2232.9806N11404.9355E000.1061830323.8706000908000102,460,0,9520,3671#","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":102,"y":130,"wires":[["15f96759.7be979"]]},{"id":"bd546645.c19378","type":"inject","z":"9b0ef6dd.ce4ec8","name":"Invalid IWAP01","topic":"","payload":"IWAP01190215V0000.0000N00000.0000E000.1061830323.8706000908000102,460,0,9520,3671,Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97#","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":112.5,"y":212.00000190734863,"wires":[["15f96759.7be979"]]},{"id":"15f96759.7be979","type":"function","z":"9b0ef6dd.ce4ec8","name":"AP01 split flag A/V TOTAL","func":"// flag = A\n//IWAP01080524A2232.9806N11404.9355E000.1061830323.8706000908000102,460,0,9520,3671#\n// flag = else\n//IWAP01080524V0000.0000N00000.0000E000.1061830323.8706000908000102,460,0,9520,3671,Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97# \nlet answer = {}\nlet elements = msg.payload.replace('#','').split(\",\")                                                           // this gives an array containing the bits\n// elements[0] is the long string starting IWAP01\nanswer.command = elements[0].substr(0,6)\nlet dateStr = elements[0].substr(6,6)        // eg \"190215\" 15th Feb 2019\nanswer.date = new Date(Number(dateStr.substr(0,2))+2000, Number(dateStr.substr(2,2))-1, dateStr.substr(4,2))    // 080524 - date\nanswer.valid = (elements[0].substr(12,1) === \"A\")                                                               // true or false - A or V\nif (answer.valid) {\n    let degreesN = Number(elements[0].substr(13,2))\n    let minutesN = Number(elements[0].substr(15,7))\n    let ns = elements[0].substr(22,1)        // N or S\n    let degreesE = Number(elements[0].substr(23,3))\n    let minutesE = Number(elements[0].substr(26,7))\n    let ew = elements[0].substr(33,1)        // E or W\n    node.warn(`${degreesN}  ${minutesN}  ${ns}  ${degreesE}  ${minutesE} ${ew}`)\n    answer.latitude = degreesN + minutesN/60        // 2232.9806N\n    if (ns === \"S\") answer.latitude = -answer.latitude\n    answer.longitude = degreesE + minutesE/60\n    if (ew === \"W\") answer.longitude = -answer.longitude                                                        // 11404.9355E\n} else {\n    answer.latitude = 0\n    answer.longitude = 0\n}\n\nanswer.speedMoving = elements[0].substr(34,5)        // 000.1\nanswer.angleDirection = elements[0].substr(45,6)        // 323.87\nanswer.signalStrength = elements[0].substr(51,3)        // 060\nanswer.satellites = elements[0].substr(54,3)        // 009\nanswer.batteryLevel = elements[0].substr(57,3)        // 080\n// LBS datas\nanswer.mobileCountryCode = elements[1]        // 460\nanswer.mobileNetworkCode = elements[2]        // 0\nanswer.locationAreaCode = elements[3]        // 9520       \nanswer.cellId = elements[4]        // 3671\n// WIFI bases only with flag = else\n// answer.wifiAccessPoints = elements[5]\nlet i;\nanswer.wifiAccessPoints = []\n    if (!answer.valid) {\n        //i = elements[4] + 1       // ns: i never used          // move on to wifi bases\n        let wifiAccessPointsStrings = elements[5].split(\"&\")\n        let j;\n        for (j = 0; j < wifiAccessPointsStrings.length; j++) {\n            let baseElements = wifiAccessPointsStrings[j].split(\"|\")\n            answer.wifiAccessPoints.push({ ssid: baseElements[0], macAddress: baseElements[1], signalStrength: baseElements[2] })  // Home|74-DE-2B-44-88-8C|97&Home1|74-DE-2B-44-88-8C|97&Home2|74-DE-2B-44-88-8C|97&Home3|74-DE-2B-44-88-8C|97\n    }\n}\nmsg.payload = answer\nreturn msg\n\n\n\n","outputs":1,"noerr":0,"x":380.50000762939453,"y":162.00000190734863,"wires":[["fe2c68ad.044f58"]]},{"id":"fe2c68ad.044f58","type":"debug","z":"9b0ef6dd.ce4ec8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":604.5000076293945,"y":162.0000057220459,"wires":[]}]
