If you have node-red-contrib-buffer parser, you can do pretty much anything you need. I imagine you actually want real numbers (not hex strings - but you can have thos too) e.g...
flow...
[{"id":"a4466e01f63dcff8","type":"inject","z":"8fb7704d922a7884","name":"03051234eeffabcd32109999","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"03051234eeffabcd32109999","payloadType":"str","x":280,"y":680,"wires":[["bd0bcb99df2b12f3"]]},{"id":"6cdb292d19b218ca","type":"debug","z":"8fb7704d922a7884","name":"debug 47","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":680,"wires":[]},{"id":"bd0bcb99df2b12f3","type":"buffer-parser","z":"8fb7704d922a7884","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"buffer","name":"asBuffer","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16be","name":"int16be","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint16le","name":"uint16be","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""},{"type":"hex","name":"str0","offset":0,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"hex","name":"str1","offset":2,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"hex","name":"str2","offset":4,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"hex","name":"str3","offset":6,"length":2,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":510,"y":680,"wires":[["6cdb292d19b218ca"]]}]
