Help with function node -string type output
Hey all can can someone advise how to make this function node to work
if (msg.payload === "A") {
return [ "true" , "false" , "false" , "false" , "false" , "false" ,"false" ];
else if (msg.payload === "B"){
return [ "false", "true", "false", "false", "false", "false" ,"false" ];
else if (msg.payload === "C"){
return [ "false", "false", "true", "false", "false", "false" ,"false" ];
else if (msg.payload === "D"){
return [ "false", "false", "false", "true", "false", "false" ,"false" ];
else if (msg.payload === "E"){
return [ "false", "false", "false", "false", "true", "false" ,"false" ];
else if (msg.payload === "1"){
return [ "false", "false", "false", "false", "false", "true" ,"false" ];
else if (msg.payload === "0"){
return [ "false" , "false", "false", "false", "false", "false" ,"false" ];
It says that function tried to sent a message of type string
Hi. So few things...
  1. Returning an array from a function node is intended for when you have multiple outputs on the function note.
  2. the return value from a function node must always be an object (or array of objects). If you intend on sending an array, assign it to the message payload property.
Try this....
msg.payload = [ "false" , "false", "false", "false", "false", "false" ,"false" ]
To simplify the function node (less maintenance)
m = msg.payload
char = "ABCDE10".split("")
out = [false,false,false,false,false,false,false]  // default all false
o = char.indexOf(m)
if(char[o]!=="0"){
    out[o] = true
return {payload:out}
ie; all false unless...
example output
{"payload":[true,false,false,false,false,false,false],"input":"A"}
{"payload":[false,false,true,false,false,false,false],"input":"C"}
Thanks guys both methods working perfect
@bakman2 - where does the ...,"input":"A"} come from in your example?
Magic!
it was to show that it the input matches with the expected output.
Hmmm, I wish I had that magic since I didn't get that using your code :worried:
