Help with how to edit OLD code
I'm going through editing/updating some OLD code.
Alas I was using var rather than let and I would like to change them all from var to let.
But as I've found the search/replace is a bit ..... wobbly.
If I search simply for var it finds all matches like variable.... which sometimes is needed to be left alone.
I've tried var (note the spave at the end) but that doesn't seem to work either.
Any tricks I've missed?
That works for me, variable will not match var with a space ?
Sod's law
It now works.
Sorry.
(Side note)
Still on solved button visible.
