Greetings. I can retrieve via FC 4: Read Input Registers the Actual and Setpoint values from my Modbus RTU enabled temperature controller. Now I want to try to write the setpoint using FC 6.
Both flows are attached. I do not get any errors or output from the Write flow.
[{"id":"d6f6bf810ef3e905","type":"modbus-read","z":"f20b61e62e9f6292","name":"temperature","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"1","dataType":"InputRegister","adr":"123","quantity":"15","rate":"60","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"a1b3011ddb70921d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":130,"y":100,"wires":[["065484719b48680c"],[]]},{"id":"065484719b48680c","type":"buffer-parser","z":"f20b61e62e9f6292","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"MB30123","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16be","name":"MB30137","offset":28,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":false,"outputs":1,"x":330,"y":100,"wires":[["5ef94a4ed46ae1ff"]]},{"id":"5ef94a4ed46ae1ff","type":"function","z":"f20b61e62e9f6292","name":"","func":"msg.payload = [\n [{\n temperature: msg.payload.MB30123\n },\n {\n MeasType:\"actual\",\n EquipNumber:\"217\"\n }],\n [{\n temperature: msg.payload.MB30137\n },\n {\n MeasType:\"setpoint\",\n EquipNumber:\"217\"\n }]\n];\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":100,"wires":[["efa94b00a95071e5"]]},{"id":"efa94b00a95071e5","type":"debug","z":"f20b61e62e9f6292","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":40,"wires":[]},{"id":"392812d56cb9a378","type":"function","z":"f20b61e62e9f6292","name":"function 2","func":"msg.payload = {\n 'value': msg.payload,\n 'fc': 6,\n 'unitid': 20,\n 'address': 137,\n 'quantity': 1\n}\n\nreturn msg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":160,"wires":[["aceb431c7c9e1380"]]},{"id":"aceb431c7c9e1380","type":"modbus-flex-write","z":"f20b61e62e9f6292","name":"","showStatusActivities":false,"showErrors":false,"showWarnings":true,"server":"a1b3011ddb70921d","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":510,"y":160,"wires":[["44b975de9deda924"],[]]},{"id":"b75a776cc0b033dc","type":"inject","z":"f20b61e62e9f6292","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"99","payloadType":"num","x":90,"y":160,"wires":[["392812d56cb9a378"]]},{"id":"44b975de9deda924","type":"debug","z":"f20b61e62e9f6292","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":760,"y":160,"wires":[]},{"id":"a1b3011ddb70921d","type":"modbus-client","name":"USB0","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"500","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"","commandDelay":1,"clientTimeout":8000,"reconnectOnTimeout":true,"reconnectTimeout":5000,"parallelUnitIdsAllowed":false,"showErrors":true,"showWarnings":true,"showLogs":true}]
In my flow, I am attemping to write the value 99 via FC 6. The slave address of the device is 20 and the address for the setpoint is 137.
msg.payload = {
'fc': 6,
'unitid': 20,
'address': 137,
'quantity': 1
return msg
The doc for this controller is here (unfortunately little or no Modbus info) and a sister product (with much more Modbus info) is here. Thanks in advance for any help here. I have done this successfully with Allen Bradley VFDs but that has not worked with this controller.
