I'm try to write a flow that send MQTT data using a short lived JWT?
The problem I running into is that the standard MQTT connection node has a static user and password and I need to change it every-time the JWT expires.
So the path I have set down is to write the broker connection in a function node, I've add the require("mqtt") to the setting.js
functionGlobalContext: {
// os:require('os'),
// jfive:require("johnny-five"),
// j5board:require("johnny-five").Board({repl:false})
mqtt:require("mqtt")
and a function node with the connection setup, also adding the client object to flow context so it can be used by the publish and subscribe function, like:
node.status({fill:"red",shape:"ring",text:"disconnected"});
var mqtt = global.get('mqtt');
var options = {
host: 'mqtt.example.com',
port: 8883,
protocol: 'mqtts',
keepalive: 10000,
clientId: 'Client001',
username: (flow.get("access_token") || 0),
password:'NotUsed'
var client = mqtt.connect(options);
flow.set("mqtt_client", client);
client.on('connect', function () {
node.status({fill:"green",shape:"dot",text:"connected"});
msg.client = client;
client.on('reconnect', function () {
node.status({fill:"yellow",shape:"ring",text:"connecting"});
client.on('close', function () {
client.end();
This seems to work the status updates on change of state but no msg are returned.
same for the subscribe function:
client = flow.get("mqtt_client") || 0;
if (client.connected) {
node.status({fill:"green",shape:"ring",text:"connected"});
client.subscribe('test/function/client', function (err) {
if (err) {
node.status({fill:"yellow",shape:"ring",text:"error"});
} else {
node.status({fill:"green",shape:"dot",text:"subscribed"});
} else {
client.on('message', function (topic, message) {
node.status({fill:"green",shape:"dot",text:"message: " + message.toString()});
msg.topic = topic.toString();
msg.playload = message.toString();
and for completeness the publish function
client.publish('test/function/client', 'Hello mqtt', function (err) {
if (err) {
} else {
node.status({fill:"green",shape:"dot",text:"published"});
} else {
