Hide or show nodes in dashboard
I have a question. Is it possible to hide or show a node in a group in UI. I know you can hide and show groups. is this also possible for nodes?
it works for groups:
    "group": {
        "hide": [
            "TabName_GroupName"
        "show": [
            "TabName_GroupName"
can the same be done for Node? For example
    "node": {
        "hide": [
            "TabName_GroupName_NodeName"
        "show": [
Thank you very much!
No, the only way is to put the node in its own group.
You can give the node a class such as "hidden", maybe by passing it msg.className.
Then CSS in a template can hide it, though I think it still occupies browser real estate.
<style>
.hidden {
display: none;
</style>
Thank you, I will try it.
