Thanks again for looking into this. I'm sure it's not easy.
I'm using a 64 bit RPi 4. The new h264_v4l2m2m codec is recording video and snapshots from only the French Bakery and Reykjavik Iceland default links. The key issues right now are:
RTSP
Do RTSP cameras work in HSS? It looks like there is an RTSP "BigBuckBunny" sample in tab named IP Cam14, but it is not working. I also tried the BigBuckBunny RTSP link in VLC, but it didn't work either. (I got this RTSP link from the injection node in the tab named "IP CAM14".)
Then, I changed the URL in the injection node to us my local RTSP cam and updated the hss_config file to use this camera, but the video still didn't show. Not sure if updating the hss_config is needed along with doing the injection manually from the CAM14 tab, but I figured I would do both.
403 Forbidden Error
I'm still getting 403 Forbidden when trying to view Recording, Snapshots, etc, from UX. According to Mozilla, that error means the server understands the request but refuses to authorize it. So it seems to be an apache config issue.
