That is right. I set up the catch node to point to use only the serial node.
Related topics
| Serial port /dev/ttyUSB0 closed unexpectedly | 3 | 1844 | 19 January 2020 | |
| Problem receiving RF data on serial port | 14 | 441 | 11 October 2023 | |
| Serialport not connected | 17 | 479 | 15 January 2023 | |
| [Solved] Serial node not working in node-red 1.0.2 | 21 | 5500 | 11 February 2020 | |
| Serial port will not work with cable already plugged in | 33 | 6503 | 21 July 2018 |
