I don't know if the heading is the correct terminology, but what I want to do is this:
Every 20 minutes my core system (a combination of Girder and Event Ghost) sends a command to the Sensibo pod with the Sensibo node, based on the temperature in the room. But the heat pump beeps every time it gets a command, and that is a bit annoying. My system does not know for sure if the current state of the heat pump is the same as the signal it sends (the state may have been changed during a restart somewhere in the system or from the Sensibo app), so I would like Node-RED to check the current state and compare it to the state that's sent. If they are the same, the message to Sensibo should not be sent.
The message from the core system is simple, a topic to trigger and then either 18 or 25 as the payload, which is sent to Sensibo. When I do a check with "GetConfig", a Sensibo in node, the result is this:
So targetTemperature is here 18. If the command from the core system is 18 as well, the command should not be sent. So how can I check the current state when the command comes, compare it to the command that comes and then stop if they are the same?
And I'm stuck in the starting block... I know I have taken out a value from an object before, but I can't remember how, and I can't find it in my flows either.
The path to the value I need is
result.acState.targetTemperature
But if I try to use that in a function node, like this:
Where you use the value just access it via msg.targetTemperature
Or if you must, use a change mode to move or copy the value to msg.payload.
2 tips...
tip 1
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
tip 2
When copying data from the debug sidebar to paste into the forum - use the "copy value" button as described in Tip 1 (that way we get actual useable JSON!)
Thanks! I didn't need to change it, it seemed, I just used the payload. And actually I knew how to get a single JSON value out of it, but I figured it would be easier to solve if I had the full JSON result. Anyway, I'm almost there! I get the two values into the function node via a join node, but for some reason I can't split it. I thought this would give me one value:
> var temp = msg.payload; var values = temp.split(';'); msg.payload = values[1]; return msg;
But it errors out:
> TypeError: temp.split is not a function
I'm used to Python (well, not used to, but I can do simple things there...) and LUA (that I'm quite used to!), but this has me stumped.
Edit: Never mind, I found out I had to convert the JSOn to a string first. So I'm getting slowly there. I have this that I need to split:
{"Fra system":21,"Fra varmepumpe":21}
But it's not working out the way I thought, this only gives me "Fra varmepumpe" and nothing more:
var payload =msg.payload;
temp = JSON.stringify(payload);
var system = temp.split(':')[1].split(',')[1];
var varmepumpe = temp.split(':')[2].split(',')[2];
msg.payload = system,varmepumpe;
No, to numbers, so I can compare them, as I said in the first post. I had gotten further, I just dropped the Fra system and Fra varmepumpe, so the combine node gave me the numbers. But the switch node was a smart thing, thanks! That should work better!
And that's weird..again. I have set both to 21 to test, but the switch says they're not equal. I did a function node to check them, and they are both listed as numbers. How can 21 not be equal to 21?
Actually, please use SteveMcL's tip #2, a debug mode set to show the complete msg object, to copy each of your input messages and past them here:
This one
Temperatur fra varmepumpe : msg : Object
object
status: "success"
result: object
acState: object
timestamp: object
on: true
mode: "heat"
targetTemperature: 21
temperatureUnit: "C"
fanLevel: "auto"
swing: "stopped"
_msgid: "ae504b43b3d89825"
topic: "Temperatur fra varmepumpe"
payload: 21
And this one {"status":"success","result":{"acState":{"timestamp":{"time":"2022-10-11T06:28:45.053423Z","secondsAgo":-1},"on":true,"mode":"heat","targetTemperature":18,"temperatureUnit":"C","fanLevel":"auto","swing":"stopped"}},"_msgid":"40d3a11ff6fdf3c1"}
(I'm not clear if those are actually the messages you are working with)
I suspect the comparison you seek is way simpler than all your splits and stringifies suggest.
It should be "msg.", not "string" on the compare... Sorry, idiot wetware mistake between the screen and the keyboard. It works now. Thanks for the help!
