How can I find the paths in a NodeRed Flow, that starts with specific node-type and ends with specific node-type?
Hello dear colleges
We have a Nodered server and we want to define some reports from the existing flows.json file regarding paths in the flows :
  1. begininng with one of the specific node types (kafka-consumer", "kafkajs-consumer", "kafka-producer","kafkajs-producer", "mqtt in", "mqtt out", "http request")
  2. ending with again one of the specific node types (kafka-consumer", "kafkajs-consumer", "kafka-producer","kafkajs-producer", "mqtt in", "mqtt out", "http request")
We want to list the found paths just with starting node and its properties and ending node with its properties in text files.(not the whole path with nodes between)
Therefore I have tried following C# code, but the code cannot find any path with this criteria , althought a lot of are existing. I tried to add also a jpg image that is showing one example , but unfortunately I got always errors during uploading.
using Newtonsoft.Json.Linq;
static void Main(string[] args)
            string jsonFilePath = "C:\\temp\\Nodered\\flows.json";
            string activeFlowsFile = "C:\\temp\\Nodered\\activeflows.txt";
            string outputDirectory = "C:\\temp\\Nodered";
            // Parse the JSON file
            var json = File.ReadAllText(jsonFilePath);
            var nodes = JArray.Parse(json);
            // Filter active flows and write their names to activeflows.txt
            var activeFlows = new List<string>();
            foreach (var node in nodes)
                if (node["type"]?.ToString() == "tab" && node["disabled"]?.ToObject<bool>() != true)
                    activeFlows.Add(node["label"]?.ToString());
            Directory.CreateDirectory(outputDirectory);
            File.WriteAllLines(activeFlowsFile, activeFlows);
            // Process each active flow
            foreach (var flowName in activeFlows)
                ProcessFlow(flowName, nodes, outputDirectory);
            Console.WriteLine($"Processing complete. Results saved to {outputDirectory}");
        static void ProcessFlow(string flowName, JArray nodes, string outputDirectory)
            // Filter nodes belonging to the flow
            var flowNodes = new Dictionary<string, JToken>();
                if (node["z"]?.ToString() == flowName)
                    flowNodes[node["id"]?.ToString()] = node;
            // Define start and end node types
            var startNodeTypes = new HashSet<string>
            "kafka-consumer", "kafkajs-consumer", "kafka-producer",
            var endNodeTypes = new HashSet<string>
            // Find starting and endpoint matches
            var results = new List<string>();
            foreach (var node in flowNodes.Values)
                if (startNodeTypes.Contains(node["type"]?.ToString()))
                    var startNodeId = node["id"]?.ToString();
                    var endpoints = FindEndpoints(flowNodes, startNodeId, endNodeTypes);
                    foreach (var endpoint in endpoints)
                        results.Add($"Starting Node: {node}\nMatched Endpoint: {endpoint}\n");
            // Write results to flow-specific file
            string outputFilePath = Path.Combine(outputDirectory, $"{flowName}.txt");
            File.WriteAllLines(outputFilePath, results);
        static List<JToken> FindEndpoints(Dictionary<string, JToken> flowNodes, string startNodeId, HashSet<string> endNodeTypes)
            var visited = new HashSet<string>();
            var endpoints = new List<JToken>();
            void Traverse(string nodeId)
                if (visited.Contains(nodeId) || !flowNodes.ContainsKey(nodeId))
                    return;
                visited.Add(nodeId);
                var node = flowNodes[nodeId];
                if (endNodeTypes.Contains(node["type"]?.ToString()))
                    endpoints.Add(node);
                    return;
                var wires = node["wires"] as JArray;
                if (wires != null)
                    foreach (var wireGroup in wires)
                        foreach (var connectedId in wireGroup)
                            Traverse(connectedId.ToString());
            Traverse(startNodeId);
            return endpoints;
It's the Id you need to add instead of the label.
As part of the introspection package there are two nodes called Sink and Seeker - they can be used to find all pathways within a flow between two distinct nodes. You add the Seeker to the beginning of the flow (i.e. the from node) and the Sink to the end of the flow (i.e. the to node). Then you open editor panel for the Seeker node and click "Find Pathways". You can also use multiple Sinks to find pathways to other nodes.
That would seem to be the functionality you're looking for?
