How can i get only the "true/false" value from array to after send to Bomba1Marcha?
I get an array, but i only need true false value.
Thanks.
You can use a Change node to move it into msg.payload.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Next is ok! Thanks.
msg.payload = msg.payload[0].run
That would be more efficient in a Change node.
Move msg.payload[0].run To msg.payload
